SDS100/SDS200: Sds100 change color per city?
noaim
Milwaukee, WI
Can you change the color of text per city or per frequency
Sent from my iPad using Tapatalk
jonwienke
More Info Coming Soon!
VA
No. You can change the alert light color per channel though.
WX4JCW
Stow, Ohio
That or color by agency
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
XPR7550 - SDS100
ka3aaa
middletown, pa.
do you have any clue how much memory that would take or how difficult a job that would be, apparently not.
Secondly why does every one want scanners to do thing their not designed to do.
radio3353
The Radio Shack (GRE) PRO-106 (circa 2008) allows the user to program a different color light for each channel (up to a point...there are 7 color choices). Why can't a $650 scanner do it? Doesn't seem to be a memory problem for my PRO-106.
mule1075
Washington Pennsylvania
The sds 100 can do it. It as the others back to the xt models the light does not stay on or blink for the whole transmission. Reason being because of the GRE patent.
JohnSC
Greenville SC
I agree, and your alert colors are similar to mine: blue for sheriff, cyan for police, red for fire, yellow for ems (almost orange) and green for highway patrol. Wish some form of this was encoded in the national database when traveling. At least law enforcement blue, fire red and EMS yellow. I've edited the locals statewide in the full database. An option would be for the state forums to work together to share their hpd files.
Color by agency gets my vote. PD blue, Fire red, Public Works green, etc..
That should eliminate the complaints about the Alert Light not staying lit throughout the entire transmission.
jonwienke
VA
If you made color a Service Type setting, it would add a total of 29 bytes to the scanner profile. Pretty sure that wouldn't be a noticeable impact on memory use under any circumstance. Coding changes would be fairly minimal.
I would change the background color instead of text color, if that didn't fall foul of a patent.
WX4JCW
Stow, Ohio
Unication does background now
Jason WX4JCW
XPR7550 - SDS100
noaim
Milwaukee, WI
No offense but older scanners did agency colored..
pinballwiz86
Missouri
I use blue for police/sheriff, red for fire/ems, yellow for amateur radio, green for the feds, magenta for business/everything else, white for airplanes, cyan for highway patrol.
cop284
Southampton, Pa
Alert light color
Can someone please tell me how to turn on the colored alert light on the SDS100?
(To assign it to a system & to change color)
Thanks In advance!!
noaim
Milwaukee, WI
I may be blind but I don't see in sentinel this is. I went to the channel itself and there was no options to change it by right clicking or double clicking
phask
zanesville
First - it must be in a fav. Llist. You can' modify anything in the main database other than avoids.
