SDS100/SDS200: SDS100 Conventional Scan
jeffj31890
SmartZone and Omnilink đź“¶
SysID: 140
Hello, I'm sure this has been answered but I am not sure how to scan conventional channels on an SDS100. It says "Scan Mode, Nothing to Scan."
Thanks.
J-Wrock
Kansas City Area
Check to make sure that all applicable Service Types are turned on - by default only a select few are turned on. Second, did you by chance program in quick keys? If so, make sure the quick key(s) associated with your conventional channels is enabled. Also, on the scanner, go to Menu -> Set Scan Selection -> Select Lists to Monitor and ensure that the favorites list with the conventional channels says "On". Hope that helps!
