The BCD325P2 does not write to an SD Card every time when you turn it off manually, because it has no SD Card. The SDS100 does. If you make any changes to your programming with the BCD325P2 it’s remembered immediately and automatically. The SDS100 doesn’t remember anything until it is shut off manually using the on/off switch on the radio, while there is still power connected. When you shut off the SDS series of scanners it first writes to the SD Card before totally shutting down. This could cause a SD Card coruption problem, but only if you intend on using the record function. (There is one other function that could also do the same as the record function but I forget what it is. /Ubbe, a little help here please.)
/Ubbe writes suggesting using a fuse tap on a fuse that looses power when the car shuts off. But while that’s how I would do it also, you’ve got to keep in mind if you use the record function on the SDS100, there’s a good chance you may corrupt the SD Card because it doesn’t get the chance to write to the card before it is divorced from power. And no one wants to corrupt the SD Card. (There have been no reports of corruption with those who use this method to shut down the SDS series provided they are not using the record function.) Since I do not use the record function with my SDS200 I have no issues with the scanner not being able to write to the SD Card when the vehicle is shut off, using the method /Ubbe describes. Since both the SDS100 and SDS200 work the same way, you will not have a problem, provided you don’t use the record function. However, keep in mind if you make any program changes to the SDS100, those changes won’t be remembered when the radio is divorced from power in the this manner. So, after you make a change you wish to keep, turn the scanner off manually, while it’s still being powered, and let it write the changes to the SD Card. Then, turn it back on. Your changes will now be remembered.
