SDS100/SDS200: Sds100 missing nxdn 9600 transmission
bmendez
Enterprise AL
My sds100 is mission a lot of transmission of nx9600 and it seems like it’s not decoding properly any steps to fix it I done everything from hold time to delay time
tvengr
Well Known Member
Baltimore County, MD
Is this the system? S and P Communications Trunking System, Various, Alabama Did you enter the RAN for each site and the CH ID for each frequency in each site? Please attach your favorites list file and I will take a look at it. Go to the File tab in Sentinel and click on Export to hpe file (Favorites List). You will need to zip the exported file to be able to attach it. Click on Attach files and open the zipped file.
tvengr
Well Known Member
Dumb question! Do you have the NXDN upgrade purchased and enabled in your scanner? Please check my previous post.
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
#1. Did you use Sentinel to program or another app?
#2. are the applicable service types turned on for the talkgroups you feel you're missing? Are you able to reliably decode anything on the system or no?
#3. Do you have a reliable signal? How many bars?
#4. Have you tried experimenting with different filter settings? Using Filters
bmendez
Enterprise AL
So when I set each site invidiual it picks up much better than having 30 sities together not sure if their is a bug with the housekeeping that the sds100 have
tvengr
Well Known Member
If you click on County at the top of the site lists in the database, it will alphabetize the sites by county and put all of the same county sites together. These are the only sites you should be using for Coffee County:
SiteNameCountyFreqs
008 (8)ElbaCoffee151.775c153.0125152.360153.365152.270
009 (9)Enterprise PoliceCoffee154.370c156.195154.445155.700155.625
015 (F)Enterprise High SchoolCoffee153.050c153.260c153.485152.285152.960
017 (11)New Brockton (*)Coffee154.430c
021 (15)VictoriaCoffee152.4125153.4025153.4475c
022 (16)ChancellorCoffee153.695c154.5475153.7175
jtwalker
Or a bug with person programming frequencies for 30 sites all together…
You have to program the sites you want as individual sites or scanner will never bother with other frequencies after it finds one good control channel.
JoeBearcat
Uniden Representative
To clarify, you have all 30 sites programmed as one site? If so, you are surprised that it's not working correctly? That's because it is only locking onto the first control channel it finds for that site and of course is not looking for additional control channels on the same site because sites are not designed to have more than one control channel. That's not an issue with housekeeping or a bug. The issue lies between the keyboard and the chair. Program 30 sites as 30 sites and fix the core issue.
buddrousa
Can you hear all 30 sites from where you are?
If the answer is NO then AVOID all sites and only use the one you can hear because you are wasting alot of scan time looking for something that is not there.
ONLY HAVE THE FREQUENCIES FOR EACH SITE IN THAT SITE ONLY.
As the Uniden Rep stated fix the sites fix the problem.
