My 996P2 and SDS200 both receive a VHF and other signals at the same. I'm running a single Onmi X with a Stridesberg multi coupler. Obviously the SDS is way better on simulcast.
And this will work fine on VHF? I've got a couple of the Remtronix 800 MHz antennas. I use one on the back of my Unication amplified charging base. And have another one I used on my BCD 436 but I remember on the 436, I had to switch antennas to get the NOAA weather where I lived. In fact the antenna that came with the scanner worked better than the remtronix did to get the weather channels.Is what I use an all portable scanners when not connected to an outside antenna.![]()
REMTRONIX 800 MHz Portable BNC Antenna | Scanner Master
REMTRONIX 800 MHz Portable BNC Antennawww.scannermaster.com
The only time I ever get 5 is during a band opening on my outside ham antenna... I just checked it on my bcd 436 and the telescoping vastly is better on the two I do receive here in the house this evening than the Remtronix 800 I bought for use on the back of the amplified charter. In fact the single long thing they sent with that charger out did it also.I get 5 NOAA sites outside on my SDS100's 436's 325p2's and 160DN and TRX-1.
Ok thanks. Like I said. I can usually get two under normal conditions on hand held devices and during certain openings I can get all 5 but at that usually only when connected to my outside Tri-Band ham antenna for 2 meters, 1.25 meters and 70cm.I am in town but not an area to be considered a High RF Area.
Same hereI get 5 NOAA sites outside on my SDS100's 436's 325p2's and 160DN and TRX-1.
You guys sure live at the right place for weather info I guess.Same here
Correct, East Coast, Philadelphia weather radio the closest, I have the Jersey Shore that has two.. pick up NYC fine, Allentown area. I can actually pick up six depending on atmospheric conditions with two stations competing with each other in Central PA.You guys sure live at the right place for weather info I guess.
I'll see what happens here. The several hour test we did some time back left the sds100 lacking severely not only on VHF but honestly here comparing it to a Motorola radio, (an actual subscriber radio programmed on what we were listening to) it missed some of the simulcast stuff. I do not remember what antenna was on the scanner. It wasn't mine. I've since had the opportunity to test a Unication G5 against that same Motorola and it did not miss anything.Correct, East Coast, Philadelphia weather radio the closest, I have the Jersey Shore that has two.. pick up NYC fine, Allentown area. I can actually pick up six depending on atmospheric conditions with two stations competing with each other in Central PA.
This is on an SDS radio.
I agree. It is not a fair test which is why this time I'll use my Unication for the simulcast test. I really didn't think anything about the SDS missing anything till we tried the Unication test against it and it didn't. I am however just as interested in the VHF analog side of things. (Which is what this thread was about) We still have a fair amount of that here and honestly when the local department slips up, some P25 VHF Simplex.As I told another user comparing a Commercial Radio to a Hobby Scanner is not a fair test.
That is the same as comparing a Real Car to a Peddle Car for speed and ride comfort.
I'm way to old for a pedal car and wouldn't fit anyway!!!That is the same as comparing a Real Car to a Peddle Car for speed and ride comfort
I think Buddy said it well in the beginning of this thread. Those who don't take the time to tackle the steep learning curve because they are too lazy or don't have the intelligence to do it are the first ones to complain about the shortcomings.. those who take the time to learn, to study, to read, to experiment, and really learn the nuances are going to get the best results from these radios.
Those who pull it out of the box, turn it on and it doesn't perform the way they want it to are the ones who complain.
We are not talking about apx 8000s, these are consumer radios with questionable quality control at what I consider a reasonable price when I think of my first programmable scanner made by Electra, the Bearcat 101 which I paid $399.99 in 1974 which is a lot more money than a loaded SDS 100 and you know I would have paid $599 in 1974 for a bearcat 101 programmable scanner, so it's all relative.
That's great. I'll see how it works out here.3 NOAA stations in my direct listening area (Eureka, CA): Humboldt Bay (covering Eureka), is the closest at 27 miles, on top of a nearby mountain; Willow Creek, about 30 miles away, but not line of sight, due to mountains; Brookings, OR, about 90 miles north, along a very mountainous coast.
That's right, 90 miles, with the SDS100 and a Comet W100RX!
And my other weather-capable radios choke on it.... Even the HP-2, with the same antenna! 😯
I just tried to see how many, I picked up 6 on my SDS200, not sure where they are. I couldn't figure that out. I'm on the west coast of Florida just above Ft. Myers FYI.I get 5 NOAA sites outside on my SDS100's 436's 325p2's and 160DN and TRX-1.
A simple Google search gave this list, NOAA Weather Radio will identify itself with its call sign on the left. You can always just Google the call sign. If you don't see the station you're listening to on this list then simply Google the call sign as it may be out of state.I just tried to see how many, I picked up 6 on my SDS200, not sure where they are. I couldn't figure that out. I'm on the west coast of Florida just above Ft. Myers FYI.
