So I am trying to monitor a county (maybe 20 miles away) that has a 3 site Mototrbo system. I simply plugged in the frequencies, digital type of "DMR", and let it scan with my TRX-1 (RH77CA antenna)
On my SDS100, Same type antenna, running it about a foot or so from the TRX-1, I have it programmed conventional, with the proper frequencies as "Digital, Code search", also Conv. with "Digital" with the proper Color Codes, as well as "Mototrbo trunk", and also as "DMR One freq", with all the same frequencies, on DMR, and I hear a blip every now and then. I have them all seperated into different "Quick keys" and finally left them all 4 on, to see if I could pick up anything.
The TRX-1 is sitting here just a talking. The SDS100 is silent. When I stop the SDS100 on the exact same frequency that the TRX-1 is decoding, programmed as a DMR freq., it doesn't even make a hit on the signal bar.
(Yes, I have DMR and NXDN add-on's applied to the SDS-100, and have received DMR on it before)
I can't imagine the TRX-1 is that much more sensitive on DMR than the SDS100. The SDS100 sure does do a good job with the P25 Simulcast systems.
Any ideas?
Any ideas?
