SDS100 question
n1riw
Provincetown, MA
I have programmed in the new system in my area. My site is set up with only the one active data channel. When I hold on this system the SDS100 sees the data channel and pickups traffic fine but I notice it keeps searching for something. The s meter and the site info rapidly flash on and off instead of being constant. I'm im ID search mode and I verified Close Call is off. Any ideas?
JohnnyGent
Banned
Banned
Chicago Burbs, IL
Any conventional frequencies on "Priority" or WX Alert on?
tvengr
Well Known Member
Baltimore County, MD
Does it say ID Scan or ID Search. If it says ID Search, it will receive any talkgroup on the system. If it says ID Scan, it will receive only the talkgroups you have programmed. When you say active data channel, do you mean control channel? You should have the control channel and alternate frequencies entered into the site. Do you see just the 1 site or do you see several sites? Is it the Massachusetts State Police system you are scanning and what site or sites are you using. There are 3 sites in Barnstable Co. The 2 Outer Cape sites require a custom Motorola 800 MHz rebanded band plan. The Upper and Mid Cape site can use the standard band plan.
n1riw
Provincetown, MA
This is the new Sarasota system...one site one frequency 851.6875...I am holding on that system with ID search and hearing traffic...I don't understand why the CC is not locked in but cycling when there is nothing else for it to be looking for
n1riw
Provincetown, MA
Nope...did have Manatee site but deleted it...just the Sarasota 1 frequency...I am trying to attach a 10 second video but it keeps saying to large to process
n1riw
Provincetown, MA
Here is a link to a video:
You can see the s meter and system info blinking on and off
n1riw
Provincetown, MA
I know that...I don't get why the scanner doesn't lock on the CC. the blinking leads me to believe its looking for something else even though there isn't anything.
sallen07
Rochester, NY
It's the housekeeping function. If you do a search for Housekeeping in the forums you'll find several thereads. Here are a couple. The second one has a couple posts by Upman that explain what's going on.
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
This is a "house keeping" feature where the signal is dropped to allow the processor to work on other tasks.
Ubbe
Stockholm, Sweden
Housekeeping are disabled while scanning only one site. Check that you have upgraded to the latest firmware.
/Ubbe
n1riw
Provincetown, MA
/Ubbe
Sentinel says I have the latest firmware
Ubbe
Stockholm, Sweden
The house keeping feature are usually done much less often than what your video indicates. The timing interval corresponds more with priority scan of wheather, prio channels or Close Call. Double check the settings for those three things again.
/Ubbe
