SDS100/SDS200: SDS100 Sentinel DotNet issue
jalexandermsgt
Nashville, Tennessee
Im new to scanning again after a 30 year absence. Doing GMRS, Ham and scanning all at once and I'm pretty confused, lol. Just got a sds100 and have ordered the programming sc card from the Bearcat Warehouse with my local counties on it. I wanted to use Sentinel, but after unzipping the file, when i try to install it says i need .NET Framework Version 2.0, download now? I click on yes and the website it takes me to has lots of version but not 2.0. Im running on Windows 11. HELP?
Enforcer52
Lake Livingston, TX
Install .NET Framework 3.0/3.5 (includes 2.0)
Also don't be surprised but there are lots of Encryption in your area for LE and Fire.
F6twistersrwindy
New to scanning. Loving it so far ๐Ÿ˜ƒ
Ohio
This is what I was needing also. Thanks again Enforcer52 ๐Ÿ˜ƒ Apparently windows 11 doesnt have it! I decided to upgrade mt 996T to the Sds200 after all. Waiting on delivery.
fxdscon
ยฏ\_(ใƒ„)_/ยฏ
What? Wheres it hiding? ๐Ÿ‘€
To install .NET 2.0....
In the Windows search bar, type "Windows features" and click on "turn Windows features on or off"
Once that window populates, look at the checkbox next to ".NET Framework 3.5 (Includes .NET 2.0 and 3.0)โ€. If that box is not checked, be sure to check it. Then click OK. After that finishes, reboot the computer and try installing Sentinel again. If your computer has Windows 11 running in S mode, you will need to disable that first.
F6twistersrwindy
Ohio
Ok. Cool thank you! I'll try when I get done updating.
hiegtx
Dallas, TX
Someone else may have mentioned this previously; if so, please excuse the duplication.
Using ProScan, you can import any programming that you had created for the 996T into ProScan and use it as a basis for programming your incoming SDS200. Of course, being a Premium subscriber, you can use ProScan to import whatever systems and channels you need from the main database for use programming your SDS200.
F6twistersrwindy
Ohio
Thank ypu. I don't recall that being mentioned. I saved the files for the 996T and have added them to the proscan setup for new scanner. Ready & waiting. ๐Ÿ˜ƒ
F6twistersrwindy
Ohio
Once that window populates, look at the checkbox next to ".NET Framework 3.5 (Includes .NET 2.0 and 3.0)โ€. If that box is not checked, be sure to check it. Then click OK. After that finishes, reboot the computer and try installing Sentinel again. If your computer has Windows 11 running in S mode, you will need to ๐Ÿ˜ƒ
Hey! It worked perfectly. Thank you so much! ๐Ÿ˜ƒ
