SDS100/SDS200: Sds100 update
DJBio
PEI
Went to upstate my sds 100 last night and it did the update and said there was a firmware update so don’t as always then did a database update and when i uploaded to the sds 100 once done it is now showing nothing to scan any help would be greatly appreciated
W4EMS
NoVA
The two updates sort of garbled my fav list and I had to go back and restore same. A really good reason to back up before updating either firmware or software but you know that now. I have not had this problem with earlier updates but I blamed it on the fact I had not updated in same time (i.e. if not broke don't fix it). Did not think to check Wiki as I have not had issues in the past. Live and learn after all it is a hobby, yes?
DJBio
PEI
I had it back up but my computer I used for my scanners crashed
DJBio
PEI
Oh wow, if only this question had been asked before or if someone had created a wiki section dedicated to this never-before-asked topic…
reason I posted instead of trying to search is I worked all day then got called back at 10pm last night to go close a section of the highway where I live do to a 2 vehicle collision with 2 fatalities and got back home at 2am then back up for work at 6:30am so my brain is not working the best when it comes to searching
dmfalk
Eureka
Suggestion: Turn off all favourites lists, then turn at least one back on. Just had this happen, myself, and this turned out to be the solution.
ofd8001
Louisville, KY
As inexpensive as SD cards are, I have several extra ones. Each "variety" of scanner has at two spare SD cards. That way if something wild and crazy happens, I can grab one and stick it in the scanner.
Can't never have too many extra, redundant or backup things when it comes to electronic stuff.
dmfalk
Eureka
This time, I don't think it was the SD card, but rather, the format of the Favourites Lists, due to the new version of Sentinel.
The new version of Sentinel changes the favourites list format, so when the SDS100 restarts to a default list, it initially can't read it, hence "nothing to scan". I found turning the lists off, and then turn what lists you want back on causes the scanner to re-read and reformat the lists in use without the parts of entries it doesn't yet understand. (Namely, the RID aliases, a new feature for the SDS150, but not yet in the other scanners supported by this version of Sentinel.)
Also, the screen layout looks a bit different........... I think the new Sentinel modifies the screen config file, too, to (attempt to) include this.
N4VKF
SPOTSYLVANIA,VA
I just updated sentinel. The software said there was a firmware update so I performed the update. I cannot find a changelog. I wonder if it had an update just to be used by the new version of sentinel.
ofd8001
Louisville, KY
I'm wondering about the notion of "The new version changes the FL format". I've not seen any posts about this previously, and I'd think there would be a ton of discussion. Especially for those who roll back firmware from time to time. Not to mention Favorites Lists being shared between different models of scanner (SDS and BCD models).
J-Wrock
Kansas City Area
The only thing I noticed with the new Sentinel update was it created a new "default" profile so all my color settings and other features were reset to factory default. I had renamed my profile based on the date I last made major changes to the programming so I loaded that and everything snapped into place. It didn't affect the favorites themselves other than the "default" profile had them set to Download: OFF and Monitor: OFF so had I not caught it, I would've ended up with a "NOTHING TO SCAN" on my scanner!
dmfalk
Eureka
The change has to do with the new ID aliases. This is a new entry in Sentinel, and meant for the SDS150, and how it gets stored. It does affect FLs, and the SDS100 isn't prepared for it.
dmfalk
Eureka
I noticed the reset of the service selections, as well.
werinshades
Chicago , IL
Alias ID's are stored under the Unit ID tab once the scanner is read back to Sentinel. This entry field has been around a long time, all the way back to the 436/536.
ofd8001
Louisville, KY
Well. . .
I just did a firmware update on my SDS100. It went the same as any other previous firmware update. No issues - began scanning just fine.
So I'm thinking user error, perhaps not following the firmware update procedure?
DJBio
PEI
Well. . .
I did the same as i always did for a update
