SDS150: SDS150 Bluetooth pairing
PCTEK
Northern California, USA
Another question. I can't seem to get my SDS150 and my iPhone 17 Pro to pair via blue tooth. I have made sure that the blue tooth setting are on with the SDS15. When I press "Pairing", nothing appears on my iPhone. The SDS150 screen says "Processing" I have reset the pairing on the SDS150 and retried to pair again, but nothing. What may I be doing wrong?
J-Wrock
Kansas City Area
Just to experiment, I unpaired my SDS 150 and phone. When I went into the scanner to re-pair, it got stuck on the "processing" screen. I had to close U/Aaware and restart my scanner, then the app found the scanner almost instantly. Try restarting both the phone and the scanner. Also, is the firmware on the SDS150 up to date? Version 1.00.43 / Sub-Version 1.03.15 came out just after the 150 was released.
mc48
Monroe County, NY
When you attempt to pair, let the app do the work. Do not manually pair, let the app connect to the 150 and follow the prompt.
PAIRING
Pairing and connection to the SDS150 must be done through the U/AWARE app. Be sure to turn on Bluetooth on the device you want to connect to.
NOTE: Pairing and connection are only available when Set Bluetooth Function is set to Enabled.
1.
Select MENU/Setting/Bluetooth Options/Pairing to begin the SDS150 pairing process.
2.
Launch the U/AWARE app on your device after enabling Bluetooth on both your device and the SDS150.
3.
Press DEVICE SEARCH in the app. The SDS150, which is waiting to connect, will appear on the app’s Device List.
4.
Select the SDS150 you wish to connect to; the pairing process begins.
NOTE: Up to 10 previously paired SDS150 names display with the most recent listed first. The oldest name drops off if a new name is added.
5.
Bluetooth Pairing Completed displays when connection is completed. Press any key on the SDS150 to exit the menus.
6.
The U/AWARE app automatically reconnects at the next launch.
NOTE: Be sure the SDS150 Bluetooth function is set to Enable before trying to connect.
NOTE: If pairing is unsuccessful, delete the pairing information from the Bluetooth settings in both the connecting device and the SDS150. After deleting the pairing information, try pairing again.
shanehanna
I get an error that says "Couldn't pair due Incorrect PIN or password", but it never prompted me for one. I have removed and started over, changed names of scanner.
