Hello I thinking about upgrading my Sd card in my SDS150, is it possible to just copy and paste the old cards data using Windows explorer, I'm just not sure exactly what to do, Any advice would be greatly appreciated
Reformatting the Micro SD Card |
| SD cards should only be formatted using the special SD Card Formatter. Cards up to 32GB are supported. After formatting, the scanner may not be automatically detected (since it is wiped clean), so you may need to uncheck "Hide empty drives" (in Windows 7) Tools>Folder Options>View before doing the next "Clear User Data" step. Then, you need to go into Sentinel and navigate to "Scanner > Clear User Data" and check "Display all drives" using Sentinel to restore all files and directories to the card. You will also need to "Write to Scanner" in the "Scanner" menu to restore your Favorites Lists. |
Thank youProbably, but I would use sentinel to prepare and write to a new card.
I just swapped out the 8GB SD card my SDS150 came with for a 32GB high performance one and all I did was copy/paste the folder from the old to the new SD card. Working fine here so far.Hello I thinking about upgrading my Sd card in my SDS150, is it possible to just copy and paste the old cards data using Windows explorer, I'm just not sure exactly what to do, Any advice would be greatly appreciated
That's what I was planning on doing,I just swapped out the 8GB SD card my SDS150 came with for a 32GB high performance one and all I did was copy/paste the folder from the old to the new SD card. Working fine here so far.
For my SDS100. I first downloaded, the data on my SDS100. To my PC, then. I replaced my 8GB with a 32GB, then. I uploaded the data from my PC. Presto!! No need to copy/paste to a new directory.I just swapped out the 8GB SD card my SDS150 came with for a 32GB high performance one and all I did was copy/paste the folder from the old to the new SD card. Working fine here so far.
You can do this without an external card reader, though a reader makes it somewhat easier & faster.I do have a question. I have never replaced an SD card before. I do have a new 32GB Samsung card. In transferring data from PC to card....Do I need a card reader/writer to transfer the data? I use Butel software so I imagine that I could just transfer the data from Butel to the new card? I know this may sound pretty basic but I and not very computer savvy. Thanks in advance.
Eugene KG4AVE
If the scanner doesn’t prompt you to choose Mass Storage or Serial Port, it could be an issue with the USB cable. USB cables can either be charging only or data-transfer. Sounds like you have a charging only cable and you would need a data-transfer USB cable. Also, a card reader would work as well. Until the scanner goes into mass storage, unchecking hidden drives and checking display all drives won't do any good as the scanner and computer aren't talking to each other.So I can't get Sentinal to recognize the scanner. I unchecked "'hide hidden drives"' and checked "'display all drives"' in the "'clear user data"' but nothing. I had this same problem updating the firmware when I first got the scanner. I finally got it to work but don't ask me how. A card reader is looking better and better.
Eugene. KG4AVE
Fair enough. I wasn’t trying to disagree or convince you otherwise. Just wanted to share what I liked.I simply find no appreciable difference at all between the two scanners, would be commensurate to the price of this new scanner. And as stated, I actually feel the SDS100, in my opinion, is actually a structurally better built scanner.
