SDS200 Display always on
catalina22
Is there a setting that will allow the display to be always on instead of going blank shortly after a call?
tvengr
Well Known Member
Baltimore County, MD
On the scanner: MENU > Scroll to Display Options > Press E > Backlight Options will be highlighted > Press E > Set Timer will be highlighted > Press E > Scroll to Keypress > Press E > Scroll to Infinite > Press E > Press AVOID to exit menu. That can also be done in the Profile Editor of Sentinel under the Display Options tab. Otherwise, you will need to make the correction every time you Write to Scanner.
