- Joined
- Feb 22, 2007
- Messages
- 6,929
- Reaction score
- 8,188
Okay I wasn't aware of what level you were at with understanding of the filters so let me take a minute here to make this easier for you. Again people might disagree but I have a pretty good understanding of the filters since they were first introduced.Thanks. I wasn't aware that there was a "filter" setting on the display. I have some empty spaces and will add that. I'll play with IFX, although it doesn't look like there is a way to set that permanently per frequency, which will be a PITA.
The filters also seem to be only settable per system, not frequency. Which someone speculated might be a limitation of the hardware.
Playing around with the filters is the apparent, but someone frustrating, answer.
First of all as far as the IFX or the intermittent frequency Exchange which changes the IF and can reduce interference... while on hold on a frequency press function 7 and IFX will show on the display. This is a permanent adjustment of that frequency and it is a global setting for that frequency anywhere in the radio including if that frequency was part of a trunked system. If it makes no difference and doesn't help just hit function 7 again and it will toggle It Off.
As far as the filters go you should always leave Global on normal. It's normal for a reason. To adjust a system you go into each site of the system and adjust the filters.
You should only be listening to one or maybe two sites in a system any way to speed up your scanning. You should not be listening to multiple sites. Remember everything is already on normal filter because that's global, everything will have normal unless you change it on the sites.
As far as an individual frequency you go into the Department settings that that frequency is in and make your changes on the filters there and yes the filter you apply will affect all of the frequencies in that Department. Many would like it to be able to be adjusted just for one frequency but that's not how it is, all frequencies in that Department will be affected.
You can get around that problem by the way you group your frequencies in different... departments.
Hope this makes sense and helps you out... Bob.
