- Joined
- Jan 5, 2003
- Messages
- 14,268
- Reaction score
- 10,202
- Location
- Retired 40 Year Firefighter NW Tenn
You get it fixed Jen it just wants attention.
Ok I won't add another nmp200 I will just find some copper tape to thicken it up so that it stays in contact. I believe the nmp200 part just isn't thick enough to stay put after a while.seth21w, I put a few layers of copper tape on the exposed part of the NMP200 piece when it's installed to improve contact between it and metal lid. It reduced the hum quite a bit more and I loved it enough to purchase a second SDS200. My second unit arrived with the NMP200 piece already installed but hum was still louder than my first was post-fix. I did the same on that unit and they're both at the same, quite acceptable, level.
It mitigates the "hum" to where it shouldn't be a bother in all but the quietest of rooms.
Of course, I imagine such a "hack" comes at your own risk. Don't lose any shavings.
More importantly, though, I would not install two NMP200 pieces. I don't think a second one would fit properly (there are plastic clips and such in the unit if you look closely; they could snap off). I would also worry about it shorting something out or damaging the LCD if attempted.
All posts are just my opinion!![]()
If you have time, can you try the following? Remove and format the SD card, re-insert, clear user data and see if it's any less.
I've seen differences with different cards, and after formatting a card. Since yours was previously quiet I'd like to see if it makes any difference.
SD card formater from Tuxera is recomeded by Uniden
Take the case off and loosen the top cover piece screws then hold pressure on the cover and tighten the screws down.Mine was stone dead quiet till last night when I noticed an annoying noise, had the tv down, the radio down and realized what it was.... I could make it almost go totally away by squeezing the case behind the plastic trim as shown in the attached picture which leads me to believe it's mechanical (so I'll hold off on the SD card format for now, but will do if needed). I didn't listen further to hear if it was mechanical hum or in the actual audio chain and coming out the speaker, if squeezing it DOES cause a reduction in the noise in the audio chain then sounds like a ground issue that the case squeeze is helping. The noise is the same with the display on or off, slight buzzing with various sparky sounding crackles, I almost thought it was lamp driver noise, the lamp timer is set to Infinate but the noise stays the same if it is swithed to 1 second... I just shut it off and went to bed, we're not on speaking terms at present, I'll listen again later and see if it gets worse..
Thanks! I actually still get some buzzing, when the display changes, through the speaker. I popped it open, it did have the part installed. It's not bad at all only audible if you're in a absolute silent room.As posted here several times all SDS200's delivered to the United States after the 1st batch has the part installed.
I also discovered the filter settings, one other major differences with SDS100 and SDS200 I found out. 20db change in signal difference!
They're right about the same as far as I can tell. With the filter off on the SDS200 the SDS100 is a little better, but by less than 3db if that even.Which one is better? in my case the 100 picks up better.
Search YouTube for hum videosDoes anyone have an audio recording of the infamous hum sound coming from an SDS200 scanner?
Yeah, I don't consider it a hum. More like a processor type noise. Mine sounds exactly as in that video. I have the "ghetto" fix installed.That could yield some unwanted results!
Ok I found this.
Is this what everyone is calling a "humming" sound"? It sounds more like an oscillating sound. Man just watching that demo, started to make my head hurt!!! I was expecting something along the lines of a 60Hz hum, which would have been bad enough. But this noise is really irritating! I don't understand why squeezing the metal case or tightening screws would help matters. It sounds as if some circuit boards are not making good contact or possibly have a crack in a trace or cold solder joint.
