SDS100/SDS200: SDS200 powers on without receiving.
Enforcer52
Lake Livingston, TX
Enlarging and filtering the pic they are both 750ma, although the one on the right appears to be older from the faded printing on it or it's just a manufacturing difference in the stenciling.
From what @drake1792 posted, I gathered the scanner didn't work on cig plug, or three pin cable. Am I correct in this?
And which one is the one that works? left or right
dave3825
Suffolk County NY
Just to confirm, you have 2 issues, right
One charger does not work with the 200? But works with the 536?
And the one that does work with the 200, the 200 not receive anything?
Its clear one power supply is bad as the 536 and 200 use the same power requirements. Where did the 200 and its power supply come from?
drake1792
Montour Falls
You’re correct. The one on the left is the one it came with and was working.
drake1792
Montour Falls
So the one that came with the 200 worked fine with the 200 and allowed it to receive.
My issue is that I’m trying to wire this into my vehicle and I already have a 3 pin dc cable that has been run to power.
The scanner will power up with all cables and functions except won’t receive unless connected to the cable it came with..
drake1792
Montour Falls
Just reconnected the original PS it came with and now the scanner also receives nothing with even that. powers up normally but even when testing simplex stuff nothing happens..
dmfalk
Eureka
I wouldn't say that the SDS200 is the defective part in this chain: it's simply drawing more power from the power supply, and the one that came with your 536 may be enough for the 536, but it's not putting out enough for the SDS200. I've seen this happen with other radios over the years - Not enough power, and while the lights are on and the speaker has some hiss, nothing is happening. I'm not sure why it won't work off the auto DC, other than the lighter socket voltage should be 12V, which the 200 needs 13.8V.
drake1792
Montour Falls
It appears to have an upgraded SD card but would that make any difference in this sense..?
kc2asb
NYC Area
Can you return the scanner for a refund? It clearly has something wrong with it.
drake1792
Montour Falls
No. Bought it off of eBay and I viewed there video of it receiving so I thought nothing of it.. my best bet is probably sending it to Uniden for repair..?
dave3825
Suffolk County NY
I have a video of cars driving over a bridge. I can give you a good deal on the 🌉
Seriously tho, if it appears the AD 1009 it came with in no, just replace that with one from scamazon. Just make sure it puts out at least 750ma. Does the 536 work with the one the 200 won’t receive with?
drake1792
Montour Falls
I’ve tried all the cables from all the scanners in the house on the 200 and they all work to power the unit on but it still doesn’t receive anything no matter which cable I use now..
Yes the 536 along with all the other scanners work perfectly no matter which cable I use…
drake1792
Montour Falls
You may have a problem on the PS board. Do you know if it was previously used in a vehicle? If so, it may have had some rough rides.
Not sure if it was used in a vehicle or not. They stated that they obtained the scanner “at the estate sale of a ham radio enthusiast; radio was sitting on a desk, plugged in.” That’s all the information I know about it’s history.
ki7fk
I did the same thing and ran into problems using Sentinel to program my new SDS200 with the same thing as my BCD536HP. I finally learned that you have to go to TOOLS / TARGET MODEL to get Sentinel to upload the file correctly. It may not have anything to do with your issue but thought I would throw it out there. You have to switch to the correct scanner each time. Hope you get things sorted out.
drake1792
Montour Falls
Understood. Yeah it has been on the correct model in the software since I’ve programmed it. We’ll see what Uniden can do for repair.. thanks!
