SDS100/SDS200: SDS200 Sentinel Quick key programming and use.
cshustak
Can someone help me understand quick key programming and use on an SDS?
Can't seem to find a video on programming these in Sentinel, and using on an SDS 200.
There is one, but it's old software.
dave3825
Suffolk County NY
Sentinel is Sentinel and I don’t think anything related to quick keys has changed in any of the releases so any quick key video will work. Make sure it’s a vid for x36 SDS sentinel and not the home patrol. I can post something later when I am at my pc.
cshustak
Quick Key Problem Solved.
If you want the quick key to work for a particular favorite, the favorite MUST be included in the Scan list under the"Set Scan Selection", "Select Lists to Monitor".
The favorites here have to be set to "ON". You can then turn them on and off with the assigned quick keys.
If you have the favorite turned off in the "Set Scan Selection", the quick key will be inaccessible.
In other words, the "Scan Selection" list has precedence over the quick key.
