SDS200E DMR Programming
rocky28965
Otago, NZ
From the DSDPlus log, scanning a control channel.
At the end of the rows, it shows either a ch number or slot number.
Should that ch number be added to the programming.
I am using Proscan.
Ubbe
Stockholm, Sweden
DSD uses the slots as channel numbers, Logical Slot Numbers, as will the actual radios in the system, but Uniden for some reason uses the frequency as the channel number, Logical Channel Numbers.
If it's a trunked system Cap+ or TierIII or MaxCap or whatever they can be called then LCN are necessary for a Uniden scanner to be able to track the calls.
/Ubbe
rocky28965
Otago, NZ
There are 3 channel numbers being shown.
There are 2 talk groups & 2 frequencies.
  • LG DRM Info.pdf
