SDS200e New user query
rocky28965
Otago, NZ
Still working on this.
I am uncertain how, where or if, to add the recently detected data to my now working DMR system.
I have been running my SDR on DSD plus, alongside the SDS200E & they seem to be receiving most of the same stuff.
From the current DSD Plus event file, I have found another Talk Group.
So now there is TG=1081465 & TG=1081885.
There are 3 Channel no's Ch=129, Ch=130, Ch=634.
There are also about 20 RID= numbers & a growing list of private call numbers.
I am curious about your setup with 2 department groups.
Group 1 with Channel 0000 & Group 2 with the TG1081855.
While in Unit IDs there are 3 groups
How all that works in ?
Ubbe
Stockholm, Sweden
I did 3 RID groups as they only did private calls between each other in the same group and they didn't use the same TG. So probably each RID group are different companies.
Look in the log which RID's that use the new TG.
If a TG are used by different RID groups then they belong to the same company but different departments within that company and that TG are a general communication of an issue in production or fire drill or similar. Sometimes there's a RID that talk to different RID groups and then it can be some sort of supervisor person responsible for the whole production chain. As its not encrypted you can probably record in the scanner and then listen and sort using Universal Scanner Audio Player and figure out what each RID groups and TG are used for and label them more appropriately.
/Ubbe
rocky28965
Otago, NZ
I'm finding the logging panel on Proscan more helpful than DSDPlus for getting the ideal setup.
I can try different formats & see the result on the panel.
