GaoJen25
After reading through some of these postings I have a larger knowledge base, and with mroe knowledge more questions.
It sounds like all Multicouplers are good over a wide range of frequencies but since CB is so low I would like to confirm this notion.
Also from searching the web I see that most connections on multicouplers are BNC I can convert form the Standard CB connector to BNC but I generally have the tendency to loose the stability of the connection.
Any and all comments would be greatly appreciated. I only need a multicoupler to connect 2 CBs to one antenna.
Thank you for your time.
