I'm using a BC-780.
PMSCAN said:Chief 71
From what I have heard over the years the Code # is a maintance code. I think Code 1 is Aircraft OK, Code 2 someting needs to fixed and Code 3 something is wrong with aircraft that is an emergency. Once again speculation on my part but your refernce to staying in the pattern would make sense if they had to burn down fuel and make an emergency landing. What freq did you hear the code stuff on ? Tower 340.700 ?
Jeffn8wb said:It started about 10 minutes before I posted the message. It was about 45 minutes in duration. I was able to figure out that one group was out of Ohio. Not sure about the other.
After the engagement, they flew along M59 west (made several references to the new Home Depot as well as Pontiac airport), then flew south over Willow Run.
detroit780 said:Those freqs I listed in the article are ones I've actually heard communications on. So they should still be good.
The other frequencies posted here should keep your radio busy.
Between Toledo and Selfridge there is a lot of activity every week to listen to. You'll even hear them pop up encrypted once in awhile.
Les
detroit780 said:There was a CAP on the 13th of this month. They usually fly them when someone like the President or VP is in town.
