Semi vs bridge (kind of), 04/26/07 Rural Alberta
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Note: I copied this from another forum I posted it in, a fire forum.. that's why the terminology used in the post assumes you have knowledge of fire/rescue operations. If anything needs clarification, let me know.)
This incident actually started late in the night of 4/25, about 23:45 hrs. Station 71 Springbank and Station 50 Redwood Meadows were sent to a rollover motor vehicle collision with entrapment on the Trans-Canada Highway just west of Calgary.
50 Rescue arrived first and found a semi-truck on its side in the "triangle" of grass just after an interchange where the road surface curved moderately to the left. The driver was still in the vehicle, with the trailer on its side and the truck 3/4 on its left side and roof. Both the truck and trailer were heavily damaged and deformed, with the vehicle body sheared off the frame.
Extrication began immediately with the crews of 50 Rescue and 71 Pump using two sets of rescue tools from both pieces of apparatus. The semi-trailer was a refrigerated van being used as a dry cargo van, hauling closet doors. The weight of the cargo destroyed the trailer body and tore the floor of the trailer away from the fifth wheel/kingpin plate. The cab and sleeper were twisted about 25° off center on the frame rails.
Evidence at the scene seems to imply the truck left the right side of the road just before the overpass and struck the pavement that lined the hill underneath the bridge, leading from the base of the road going under to the base of the bridge crossing over. The truck didn't make contact with the bridge itself, but the impact with the cement tore out the 6ft driveshaft, embedding it in the ground to where only 18" remained visible above the soil. The truck continued under the bridge and straight ahead, as the road (as mentioned) curved to the left. The truck continued to roll onto its left side and ended up in its final resting place about 200 feet beyond the bridge in the grass verge.
Extrication took 1 hr 41 min to complete. At one point, a heavy rescue from the City of Calgary was special-called, but was canceled en route when the onscene crews managed to complete a successful extrication.
Photos:
The pavement under the bridge; in the far background are an ambulance and the rear of the trailer.
15-20 feet closer than the above photo, showing the driveshaft and the semi. In the upper center of the picture, the reflective stripe is the rear frame of the tractor/prime mover, which is still attached to the fifth wheel/kingpin plate, and the trailer by means of part of the body cladding.
Closeup of the driveshaft, pointing in the direction the truck was traveling. The hard-packed, frozen-until-recently dirt is churned up to the point of feeling like soft loam soil.
Looking down the truck from the road towards the cab... what you are seeing is the roof of the trailer. The pink stuff in the foreground is part of the insulation of the refrigerated trailer.
Overall view of the two crews working on the extrication. Ultimately, the windshield was removed and the passenger A pillar; later, relief cuts were made in the roof above the passenger B pillar and a ram was used to push the composite steel/fiberglass roof up with the ram positioned where the passenger A pillar had been. As much of the steering wheel as could be accessed was cut.
Closer shot of the ongoing rescue effort.
Three tension buttresses were used: One, shown below, wedged into the sleeper roof, one into the shortnose engine cowl, and one (next picture after) against a frame rail on the opposite side.
Oh, and the injuries... appeared to be not much more than either a fractured or dislocated knee, some cuts and bruises, and minor shock.
DX-300
Alberta, Canada
Wow! lucky, lucky!
And I can't get over that drive shaft, just pressed right down in there like a knife in butter. Mind boggling but one must agree that when you have a couple thousand pounds and its moving it'll pack quite the punch!
