Sentinal, SDS200, Missouri Statewide programing
n0wla
Lees Summit, MO
Tried many time to program Lafayette County MO into scanner via Sentinal with no success. End up with lots of other counties on the system and even at that nothing heard. If I delete the unwanted counties then it doesn't show up on FL. I am within range of Lafayette County, I'm next door in Jackson county. I have had the radio for a few years and successfully programed it with other systems.
Whiskey3JMC
LMR Explorer
Philly burbs 🇺🇸
Use Proscan for programming. You get selectivity over systems/sites/depts/talkgroups you want to add, no need to delete the objects you don't need. You get a 30 day fully functional trial to get what you need programmed then beyond the trial period $50.00 gets you two license activations and frequent product updates. Only prerequisite is a RR premium subscription to utilize web import which you have already. Check it out!
