Sentinel: Sentinel HPDB?
RandyKuff
Lorain, Ohio
My guess is there are 3 jobs. One to pull from RRDB, then the other two to generate the appropriate database files for each series. If you're using the same source data set for multiple outputs, this is industry best practice.
That could be...
RandyKuff
Lorain, Ohio
I know the Database files are the same for both series... But there is a ".gz" file in the updater folder that is different for both...
JoeBearcat
Uniden Representative
Got me wondering too...
x36 and Homepatrol for the HP1 and HP2... Whats the third one?
Bear Tracker 885
I don't know if it is three DLs or one DL that is processed into the three files. I suspect the latter.
bravo14
Polk County FL
A moment ago went to see if the update would update sure did. Guessing a server issue for certain areas....
fxdscon
¯\_(ツ)_/¯
Down for me as of Noon est 9/30/2023
What error message are you getting when you try to update? I just updated the BCDx36HP Sentinel on my laptop from 9/10/2023 to 9/27/2023 with no issue... just a few minutes after your post.
RandyKuff
Lorain, Ohio
Why are they behind...
The 10/15/2023 release isn't available till sometime after 10am EST on Monday 10/16/2023...
