SDS100/SDS200: Sentinel program issues sds100 and osp
krackers80
newark Ohio
I have a sds100 and all my programming is working except osp ohio state patrol I put it in its own favorite spot and no matter what it is only one that says nothing to scan no other is having this issue. I did use the frequency from the ohio marcs-ip multi agency part. i am using sentinal software any help with this will be nice thanks
donc13
Grand Junction, CO
Many (but not all) of the OSP talk groups are encrypted and no scanner will receive them
RandyKuff
Lorain, Ohio
Sounds like you don't have something setup right...
If you created a favorite list with just the OSP and your getting "Nothing to Scan" from that favorite list, check your profile settings in Sentinel for
"Download and Monitor" and make sure they are checked for that list before loading to the scanner...
You do realize that the Marcs IP system is a trunked system... It's more than just entering a frequency... What "Site" frequency's are you using...
You did not say what your location is....
These are the Control Channel freqs for my area... (Top right)
This list is for District 3 talk groups for my area for example...
mass-man
trying to retire...
Parker Co., TX
+1...ran afoul of this several times in my Sentinel journey!!!
RandyKuff
Lorain, Ohio
I did mention that above too... ;)
krackers80
newark Ohio
my question is I'm in licking county ohio we have 6 towers here and just got 1 simulcast tower. on my sds100 can I take out the 6 original towers and just use the new simulcast tower or do I need all 7 programmed in it
firemantom26
Wintersville Ohio
You can take out all the sites that have gone or will be going to the siimulcast. You will need to leave Reynoldsburg in, because they’re not part of the simulcast.
wa8pyr
Staff member
Lead Database Admin
Ohio
Specifically (as soon as they're confirmed off the air), you can remove Pataskala (127), Johnstown (159), Granville (165), Newark (166), Hickman (167) and Linnville (168).
krackers80
newark Ohio
if the old towers are left programed will it harm any thing besides more to search threw
krackers80
newark Ohio
ok i have a marcs system on my sds100 with 4 of the 5 tower sites programed in it how can i add the 5th. every time i try this it adds like 90 sites for the whole state how can i just choose 1 site to add to a existing favorites list
tvengr
Well Known Member
Baltimore County, MD
To add a sIte manually using Sentinel: Click on the Edit tab and Edit Favorites List. Select the favorites list and click on OK. In the left pane, click on the trunked system. Click on the Sites tab. Click on the green plus sign to add a site. Name the site. Select a site quick key, site filter and site NAC if desired. Click on the new site in the left pane. Click on the green plus sign to add as many control channel capable frequencies as required. Enter the frequencies. If using GPS, click on the Location tab and enter the Latitude, Longitude, and Range. Click on the File tab and Save. Click on the File tab and Exit. The site has now been added to the system in Sentinel.
