BCD436HP/BCD536HP: Sentinel Software question
K2KOH
Silent Key
Putnam County, NY
Everything should be in the database, which is updated once a week. If you want to listen to something specific you can create a favorites list. I don't think there is a system download function like the GRE or older Unidens had.
mrkelso
NNJ
Every so often use Update Master HPDB That will keep you up to date so that when you create your fav's you will have the latest info in the database available.
ofd8001
Louisville, KY
Just to sharpen the pencil a little more. . .
The Sentinel master database is a download of the Radio Reference database. Thus the Sentinel database is the RR database.
Typically it is updated once a week with the past ones done on Sunday. If you look at the lower left hand corner of Sentinel, you will see a field "Database Version: xx/xx/xxxx".
Butel Software has a couple of programs, ARC536 Basic and ARC536 Pro, which have a feature that will allow you do download data from the RR database for those who are premium subscribers (which I see that you are).
