Sentinel trashed Micro sd
Ok so today I took my Microsd card and did a erase favorites list and a force write full database and I came
up with a cyclic redundancy error.I tried everything to fix it (as far as my comprehension) A full format,quick format and a check disk.Seems normal but when I go to put the data back on it still says cyclic redundancy error! All I have to say is Im baffled!
Well all i wanted to do is put in new favorites list and delete the old ones (2 old ) 59 new.
Thank god I have a backup card,I put that in,and wrote the new 59 favorites lists and Im fine.
What the deuce is with the other card,everything is brand new......
keep in mind if I didnt change the lists that card would be fine too.
Any ideas?
MORSEMAN
Mesa, AZ
I had a similar thing happen one time. I use a free SD formatter called SD Formatter Ver. 4.0 from sdcard.org and was able to recover it.
FirstClass
Southeastern Pa
SD Card
Did you use SD formatter? If yes it may be a bad block in the beginning. Windows may default to Not There File System (NTFS). The SD card should be FAT 32
weird
I put it in a card reader I couldnt fix it,for some reason it worked after I formatted it using the computer's built in card reader/writer.Go figure....It was a hoot trying to get it back working though.
