Service types vs. personal programming
trentbob
Silent Key W3BUX
Bucks County, PA
If you personally program, you don't have to put a service type in, it just automatically reverts to custom.
n1chu
Farmington, Connecticut
If you use a different service, what you call “personal programming”, isn’t that now the service? I believe the RR database as compiled, was assigned a particular service and that service can be changed by the end user. So, if the RR database lists the service as Fire Dispatch you can change it to something else, such as Fire Tac. I don’t believe the scanner remembers what the original programming service was if you change it. Is that what you ask? If so, hope this helps.
Chris0516
Pittsboro, North Carolina
I am asking, in the sense that, the service type has something interesting that I didn't think to program or, I program something the Service Type doesn't have.
Chris0516
If you program a Public Works frequency, and turn the Public Works Service Type off, the scanner will skip that frequency.
That makes sense. I don't listen to any DMR, NXDN, Public Works, School Bus or, Airline (non-flight)communications. Just ATC, (digital)RCAG, (digital)911 and (digital)SHP.
Chris0516
I never considered 'personal programming a 'Service Type', but okay. I don't think a scanner remembers, either. If it is changed.
trentbob
Silent Key W3BUX
Bucks County, PA
Because I don't use GPS and I don't use zip code scanning, I don't even have service types on my display. I eliminated it as I did a lot of things.
Nothing has changed for years that I listen to so my 100 and 200 are the same program that I've had for a long time. Every once in awhile I might read about a frequency or something I'm interested in, I just manually put it into the radio and add it to one of my favorites lists and when I get to the option to put a service type in I ignore it and it goes to custom. Custom has to be enabled for me to hear it and it always is.
I have all of my service types turned on. If I want to control what I listen to I use the avoid button, not by enabling or disabling certain service types.
In reality you will find that the service type label on a talk group or frequency has absolutely nothing to do with reality of what the object is, it just isn't labeled right it's tac instead of dispatch or dispatch instead of tac, It isn't always accurate or relevant.
For example there's a local UHF repeater for a small town near me that is on our tdma Phase 2 simulcast County system for dispatch of fire and police. This UHF repeater frequency is used just by this town by the mayor, EMA and as a car to car for the police that is off of the county system. The county does not monitor it. It has a fire tac service type.
Since things rarely change in my programming I do a lot of stuff right on the radio itself using the keyboard which is fine, again if I program a new frequency, like maybe a new VHF digital conventional Coast Guard frequency I don't even attach a service type to it, I skip that option, it just goes to custom 1.
I rarely hook up to the computer anymore because obviously we don't have firmware updates that are relevant or useful since April of 2019 unless you have a new radio with hardware that needs to be accommodated.
I update the database once in a blue moon but again I don't use GPS or zip code scanning but when I do hook up to the computer I make sure that I transfer my card to my profile first thing and that saves all of the changes, like filters, avoids, new frequencies, offset volume adjustments Etc. On my profile.
When you're done your business and you transfer the card back to the radio all of the changes I made on the radio prior to hooking up to the computer are permanently saved on the radio.
If I didn't transfer the card first thing to my profile before doing anything else and went ahead and did my business and then transferred the card back to the radio I would lose all of the changes that I made on the radio like new frequencies, filter adjustments, avoids Etc. It would revert back to whatever was in the profile before I hooked up.
JoeBearcat
Inactive member
Uniden Representative
Will Service types override personal programming? If personal programming is different from Service type?
All channels have to have *a* Service Type, so in that sense the answer is that yes any disabled Service Types will 'override' the channel being actively scanned. As was mentioned, they default to Custom 1.
