This is entirely too cumbersome Gommert. I'm not even sure it will work.
It's cumbersome to say the least and is prone to me having different profiles loaded on my 396XT and 996XT.
Even if I use Batch Import, I have to manually select the particular files I want to import. In a complex profile that can be over 100 different systems. That's what a profile is supposed to prevent, but ARC XT won't allow me to move a profile from one computer to another, even with a shared HD.
There really has to be a better way that doesn't require me to use Freescan or BCTool. The way the program is configured is not acceptable for those of us with multiple computers and multiple scanners.
I feel the same and find myself using ProScan now more than anything. It also handles RR direct to scanner downloads with my old BC-780XLT.
ProScan, like Freescan, will save everything in a single file which makes moving it to another computer a breeze. ARC-XT's method is just strange and often confuses me. I've already made mistakes by trying this which should be very simple but I've lost programming somehow. I'd first used ProScan though so I had a backup that I did use to restore my 996XT from. I found it too easy to miss a file for a system when trying to move the data to another computer from ArcXT Pro's data files. I don't remember why I was even doing that but I think it may have been due to a new computer or recovery after replacing a bad drive.
The good thing about the way Butel does it is that it makes it easy to send someone a "system" from your scanner without needing to send the entire scanners worth of data. I've done that before with a buddy in Canada that was having issues with a system their. He sent me the file for just that system which I was easily able to add into ArcXT Pro and then send to my 996XT.
When I was done, I simply removed that systems file from my drive and that was that. I had to also remove it from the list of systems in ArcXT Pro and send the data to the scanner but no big deal. I do like that ability which none of the other packages provide.
I also never liked the way GRE's PSR500 and 600 work, it is all or nothing when you read and write the scanner. I'd much rather have the ability to upload a single system like I can with the Uniden's instead of uploading everything each time. That is not a super big deal though as the 500 and 600 do upload the entire shebang pretty fast.
As far as Freescan goes, it usually works but I have had it corrupt the data sent to my 996XT or T before so I never fully trusted it. In Freescan's credit, that happened a long time ago and Freescan has had several bug fixes and updates since. The problems I had in the past appear to have been fixed but I still get a funny "here goes nothing" feeling when I use it so I still use ProScan first and make a full copy of everything before I use Freescan. I really only use Freescan when I need to do something say at work where I don't have ArcXT or ProScan installed due to being paid programs. ProScan does allow install on two computers but I've used both on computers here at home. Not sure on ArcXT's policy regarding installing on more than one computer you may own. I've never tried it on a second computer due to the odd multiple files per scanner thing that this thread is about. It just seems awkward to use it on more than one computer for the same scanner unless you synchronize the folders between the two computers first. Files are many and it can be hard to figure out which you need to copy so you can duplicate everything on another machine.
I think every programming software out there, free or paid, has something that I don't like! So I have almost all of them.
Not one single one works perfectly for my needs but ProScan is the one that is the best for me. Freescan is second when I need to do something on a computer without any programming software on it. I used to be all Butel until ArcXT and ArcXT Pro came out. I think that is about when the multiple files per scanner started. I don't recall if the version for the old T models also has multiple files for a given profile.
I still like and use ArcXT Pro pretty often but I find myself using multiple copies of ProScan running each of my Uniden scanners at the same time these days. Mainly used for logging purpose though with the new statewide system that is coming online here. I can copy several towers so I set each Uniden to a single tower and let ProScan run an instance for each scanner from different folders. It works very well for that.
The nice thing about Freescan is of course that it is free but what also makes it nice is that you can download your programming and email it to someone else that can't afford software providing they are using a supported Uniden model and Win machine. It's also good for someone having troubles as they can use it to download their scanner and email you the file for inspection and error correction. Everyone can use Freescan which makes it kind of a universal Uniden programming platform. I only wish they made the same for the GRE radios!
I think it will even run on a Mac with Parallels or one of the other Windows emulators installed. So the Mac users are not left out in the dark. Not sure about running it under any of the Linux versions though but I bet it has been done.
I've never used BCTool so no comments on that one.
