j_kind said:
Thanks for your replies. Very much appreciated it. I received it today 6 weeks exactly from when it was sent out !
Now i have to figure out how to program it. I read and reread the instructions and still confused. :?
thanks
I have the R5, and it is NOT for the weak of heart
Actually, once you get used to it, it's not that bad. You can hit the band button and it will run through the different bands, then use the tuning knob to get to the frequency you want. Getting the frequency into the memories, and then dividing everything up is also aggravating, as there are multiple steps. May I suggest the Icom R5 programming software? I know it sounds pricey, but at the same time, it makes programming the little beauty a lot easier.
Good luck!
Kieran
