kyle_in_rure
- Joined
- Jul 1, 2013
- Messages
- 5
Hello, new member here. I recently discovered Shortwave radio, and have made a habit out of listening frequently. I am using the Tecsun PL-600 portable right now.
I have about 60-70 ft of #14 insulated wire strung across the yard, which I was using for an AM crystal radio set I built a while ago. The wire transitions to about 8 ft. of RG6 coax via a soldered connection in a plastic bottle outside. I thought about trying to use it with my radio, which uses a headphone jack as an external antenna adapter. I bought a headphone plug and connected it to the antenna with an alligator clip. Wow! I was able to pick up much more than I could with the radio's telescoping antenna alone. I even picked up WWV and WWVH (the time signal stations) at the same time.
Here is my ultimate question, I would like to run the antenna wire inside. I thought about doing a similar setup like my TV antenna is now: about 30 ft of coax outside, through a window via a flat coaxial cable (NOT twinlead, they sell them at RadioShack). However, will I lose a lot of signal through 30-40 feet of coax? Also, what do I do about grounding? Right now I have the coax shield just cut off, it is not connected. I could always run it through a grounding block like my TV antenna is. I wonder about signal loss here, as well, however.
Thanks in advance for any information.
