One other possible cause that folks in the Microwave Radio world ( analog days especially ) experienced was "
Fresnel Zone" issues and also typical temp inversion issues, especially during Spring & Fall....Fog, light rain / mist and tree leaves can (
at times) significantly attenuate receive signals from my experience. That's were Space & Frequency diversity helped mitigate the issues somewhat. These may or may not be a contributing factor, but we have seen it happen....
Why not take a ride to a close-in Transmitter(s) and confirm you have good receive at that (or multiple) location(s)?
LINK:
https://en.wikipedia.org/wiki/Fresnel_zone
That would validate your scanner is correctly programmed / decoding and takes that out of the "what if" questions....Better Coax (LMR) better antenna or YAGI's higher if possible might help too, in some cases - not all. Some use a proper AMP but that too is not always the right solution either...An RF Filter for the 800 MHz band is another option (not cheap) and that helps if you are getting strong RFI and migh be overloading the receiver - not likely, but an option.
Just a few ideas to ponder, but a simple "
road trip" would be the first thing I would do to as a logical/simple trouble-shooting method....
Just my opinion and hope you get it solved as here in the DFW area we have issues with P25 Simulcast and heavy RFI (
now some G5 interference too) that can drive you mad trying to get the best solution's that work for your specific location and station.
I go up that direction once in a while and if think about it will bring my SDS200 and see what I get...
Hope you get it worked out.
Bill
