Simulcast question
dan9125
Lockport
Is it possible with a SDS200 to know which tower in a simulcast system you are receiving, Just curious in Niagara County NY which sight I am picking up. Thanks in Advance
Dan
W1KNE
President, Scumbag Society of America.
Southern New England
Unfortunately the answer is no. While @wtp 's answer may seem wiseass, it's fairly correct, too.
The unique sites all broadcast the same Site ID number, so only by using a highly directional antenna and calculating it out.
prcguy
Better to use a small loop where the null has a much narrower beamwidth than gain on a huge Yagi. Like +/- 30degrees for 3dB change on a Yagi vs +/- 5 degrees for maybe 10dB change on a loop. You can really narrow down a tower with a loop.
k2hz
Rochester, NY
Except the loop has 180 degree ambiguity and you are working with a sharp null rather than a peak. You also have the situation of multiple transmiiters in simultaneous operation which would make it difficult to find a null for a specific transmitter. The only relaible method is to go to the suspected tower site. But, that would not prove what tower you are hearing at home. I see no point to this discussion.
GTR8000
NY/NJ Database Guy
BEE00
If you're in Lockport as your profile suggests, there's a very good chance that you're receiving signal from at least 3 subsites in that area.
ThePagerGeek
To the OP, "Is it possible with a SDS200 to know which tower in a simulcast system you are receiving...?" The answer is not binary. In a simulcast system, multiple towers work together to provide signal coverage, as mentioned above.
If you are looking for the closest tower in that cell, a simple FCC search (here on RR or FCC ULS) will give you the coordinates of all towers in the system. No special antennas needed.
