SLOT Opration
ham2020
Is it possible to run two groups without overlapping of course each group on a separate slot without repeter
Or is it necessary to repetter in order to operate the two groups on the slot properly
WA0CBW
Shawnee Kansas (Kansas City)
The repeater provides the timing/synchronization for each slot. I know Motorola has software that allows one radio in a group of radios to provide the slot timing/synchronization, however all radios in the group must be able to hear that radio.
bb
dazey77
Hytera can still have two simultaneous calls on one frequency in simplex but not in the same way. They had to get rid of the TDMA mode which creates two logical channels on one frequency. They still have pseudo trunk which can put handle two simplex calls/freq but on one logical channel. You could still have your two groups operate on one frequency but one group can interfere with another if they use up both slots.
Personally I find the pseudo trunk more useful than TDMA mode but they both have pros and cons
Pittsboro IN
I could not get pseudo trunking working in simplex mode.
I have clients using BD302s so they don't even have pseudo trunk as an option.
dazey77
Never had any issues getting it working, just need radios that have the relevant licence! If you have a Hytera radio that doesn't support it they lock onto the first slot that is open even if its not relevant. You can mix and match with limitations (all hyteras that I have tried only transmit on one slot in simplex)
ergbert
FN22
I've got a PD362 using TDMA mode, playing nicely with a handful of Moto radios using DCDM. The only thing that doesn't work for some reason is private calls from Moto to Hytera. The inverse works just fine.
dazey77
I have a moto working with Hytera and doing private calls (not using TDMA). Generally private calls failing come when there is a difference between ‘private call confirmed’ status.
Note that current PD362s do not support TDMA (only pre-i firmware supports it)
On the Moto I use ‘private call confirmed’ and ’data call confirmed’ and ‘DMR standard’ for data.
I think I have had private calls working unconfirmed as well but I can’t be sure.
Text messaging also works between brands but only on a firmware 2 PD365 (or in my case a PD375). The gen 1 PD365 can only do Hytera data so won’t work with moto. The Hytera / standard data switch is only in version 2 firmware which means a PD375 or a gen 2 PD365, which you will be very lucky to find with pre-i firmware. New ones have i firmware now.
dazey77
(Your description sounds like the moto is trying to do confirmed calls and Hytera are doing unconfirmed hence working one direction and not the other)
Pittsboro IN
Does the data bearer service under conventional / digital common / basic have anything to do with private call confirmation?
The default is Hytera, not DMR standard.
dazey77
Don't think that the data bearer service has anything to do with private call confirmation. Was just dumping all my hytera/moto interop experience in one spot and also adding just in case since I know that DMR standard is a deviation from norms and its been a while since I first set them up and experimented.
