Software for R30 receiver
theoldcop
Wilmington, NC
Yep! Gommert, as responsive as usual, fixed the issue the same day! Beta 3 working great. Thank you Gommert!
Hit_Factor
Saint Joseph, MI
GPS data and existing bank names do not appear to be preserved. Import a csv from the radio, then export CSV from ARC30. The names and GPS data don't seem to be in the exported CSV. Perhaps I'm doing something wrong?
tumegpc
Southern Oregon
RTSystems IC-R30 software
Just installed the RTSystems IC-R30 programming software. I like the extensive Radio Menu settings there is two tabs with about 90+ settings to work with. I also like that you can change the font type and size in the software. So much easier to read when programming. It does utilize RadioReference database with this program !
I like what I see so far. Thanks RTSystems !
bgav
Central MA
Just installed the RTSystems IC-R30 programming software. I like the extensive Radio Menu settings there is two tabs with about 90+ settings to work with. I also like that you can change the font type and size in the software. So much easier to read when programming. No RadioReference database with this program.
Website says interface with RR. Do you need a premium subscription?:
  • RT Systems WCS-R30 Programming software makes it easy to manage memory channel information and other menu settings of the Icom IC-R30.
  • Spreadsheet layout with many point and click options.
  • "Read" the current configuration from the radio for editing or start from scratch in a new file.
  • The programmer has copy and paste of memory channel information between files.
  • Column editing for changing several channels with minimal typing.
  • An easy interface to ARRL Travel Plus, RFinder-Worldwide Repeater Directory, Radio Reference, or Repeater Book to get repeater information. (separate purchase or subscription may be required)
  • Ability to copy and paste spreadsheet or website data.
  • Much more than just memory channel programming with settings for other radio menu items.
  • RT Systems Programming Software for Windows 7 (32 and 64 bit), Windows 8 and 8.1 (full version), or Windows 10
Wally46
Clinton, Iowa
I bought and downloaded the software. The program doesn't even "see" my radio. I can't upload radio info to the program.
Hit_Factor
Saint Joseph, MI
My computer can see and access the files on the Icom IC R30 though with no problem
I'm having trouble seeing my receiver as well. Can you outline the steps you take?
BTW, The ARC30 beta 4 software looks pretty good now. It reads in existing bank names and GPS data.
Hit_Factor
Saint Joseph, MI
I'm having trouble seeing my receiver using the RT Software (other methods work OK). Can you outline the steps you take?
Hit_Factor
Saint Joseph, MI
Turns out I wasn't using clone mode.
On the r30: menu/others/Clone/Clone Mode/Yes
In RT Systems: Communications/Adjust sending speed/Fast
Communications/get data from radio
tumegpc
Southern Oregon
No need to SET :On the r30: menu/others/Clone/Clone Mode/Yes . I even went into the menu and set it to NO and the R30 will automatically connect . All I did was have USB CONNECT to Serialport- USB Serialport Function set to CI-V Echo OFF.
No need to go into the menus - Just connect and the software will do the rest .
And you are correct about -Adjust sending speed to - Fast in the software.
DonWetter
RT Systems IC-R30 issue
Anyone having issues with the new RT Systems IC-R30 software (version 5.00.16) saving changes to the operating mode? For example, I tried to change FM to NFM and it will not save the file correctly reverting back to FM.
Don
Hit_Factor
Saint Joseph, MI
Don
Yes, I reported it to them this morning. Domenic said a fix should be out today. Try running the updater.
Hit_Factor
Saint Joseph, MI
Now that I have the 1.10 firmware on my R30 the RT Systems errors at the end of the communications/get data from radio function. Anyone else having the same problem?
