prcguy
- Joined
- Jun 30, 2006
- Messages
- 18,962
- Reaction score
- 15,439
Thinking about the hundreds of apartment units I'll add a final comment on what I might do realizing limited access to a communications closet. First I would install a ground block on the coax before the modem and connect the ground block to the third prong of an AC plug into the nearest outlet. Each individual apartment should have its own circuit breaker panel. I would get and install both a Delta LA302 MOV type lightning arrestor across a pair of existing 20 amp breakers (one on each 120V leg of a 240V feed) that has very little use and a matching Delta CA302 surge capacitor across another pair of lightly used 20A breakers. With most light bulbs being replaced by super low current LEDs a breaker specifically for lights is a good target, or if there are unused breaker slots install new breakers just for the Delta units. Then a Jensen VRD-1FF CATV F type isolator on the modem side of the ground block.
This will place the CATV line at the same ground potential as everything in the apartment and the Delta units will lessen the chance of damage to electronic equipment from a couple thousand volt jolt. Its a few hundred $$ in parts but cheap insurance and when you move you can take the parts with you. If there is a huge spike on the AC lines during a strike its a very short event and the Delta units will absorb the spike and usually blow the breaker, but the event will be over before the breaker trips. The Delta units should be good for many strikes, especially in a huge complex where they are just across one breaker panel out of hundreds.
Here are links to the recommended parts if interested. I've installed the Delta units in several places of mine and for friends.
Amazon.com: Delta Lightning AC Surge Arrestor - for 120/240 VAC Water Wells, 0-300 Volt AC, | LA302 : Electronics
Buy Delta Lightning AC Surge Arrestor - for 120/240 VAC Water Wells, 0-300 Volt AC, | LA302: Surge Protectors - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: Delta CA302-R 2-Pole 125/250VAC Single Phase Surge Capacitor : Industrial & Scientific
www.amazon.com
Jensen Iso-Max VRD-1FF 75 Ohm Inline Digital CATV Isolator Hum Eliminator
Jensen Iso-Max VRD-1FF 75 Ohm Inline Digital CATV Isolator Hum EliminatorThe VRD-1FF was engineered for use with composite video systems, and is used to remove ground-loop hum and "hum bars" from signals in virtually any application. With high quality F cables, connect the VRD-1FF between your...
www.parts-express.com
