Speaker magnet.
Delivers1234
Modesto, CA
Hi. So what have two 2x2 5watts road pro speakers. After finally deciding, I would like to mount them facing down under my headrest.
I know there might be better places.
The headrest will have to stay up which it always is. There is a crevice on the bottom of the head rest between the 2 poles.
My question is.... do I need to worry about the speaker magnets being about 3 inches from my neck/head????
The speakers are enclosed with the hard plastic case( as other communication speakers).
Thank you. I'll try to edit and add a photo.
jonwienke
More Info Coming Soon!
VA
There is no health issue with body parts being near a static magnetic field, unless you have metal objects embedded in your body for some reason.
The only potential health risk is with alternating electromagnetic fields that result in energy being absorbed by body tissues.
Also, speaker magnets generally form a closed magnetic loop that results in minimal stray magnetism.
It's not something you should be worried about.
RFI-EMI-GUY
This is in a vehicle? Unless you duct tape your head firmly to the headrest, it won't be a static field. Probably wont kill you but, why would you want to risk it? Read up on transcranial magnetic stimulation.
Delivers1234
Modesto, CA
Here is my pic. I am facing the driver seat. My hand is holding up where the speaker would go.
RFI-EMI-GUY
Those are small, the magnetism probably won't kill you as I said, but what if in a collision they dislodge and wedge between your spine and the seat?
jonwienke
VA
Which is done with high-frequency alternating magnetic fields, not static fields. Do you even science, bro?
Unless you're talking magnets orders of magnitude stronger than those found in an MRI, normal body movement will not induce currents in the body sufficient to have any detectable effect whatsoever.
royldean
Schwenksville, PA
Lots of miata's out there with speakers in the headrests....
not mine, though. But for free, I'm not going to complain....
RFI-EMI-GUY
Yep I really do science. The OP said he was going to attach speakers to his headrest. I pictured some oversized communications speakers with powerful neodymium magnets, not those tiny ones. My point is that unlike some headphones firmly planted on your head, mounting them on the headrest by your head is NOT a static field because your head will be moving while the vehicle is in motion. Picture your head as an armature in a fixed stator field.
Really at this point the danger is mechanical one in event of a crash.
RFI-EMI-GUY
I'm going to Velcro them then rope a strap around them to the poles.
So the magnets seem small enough to not pose a dangers etc?
Probably, no guarantees in life! YMMV ,
Standard Disclaimer
This product/advice is meant for educational purposes only. Any resemblance to real persons, living or dead is purely coincidental. Void where prohibited. Some assembly required. List each check separately by bank number. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Postage will be paid by addressee. Subject to CAB approval. This is not an offer to sell securities. Apply only to affected area. May be too intense for some viewers. Do not stamp. Use other side for additional listings. For recreational use only. Do not disturb. All models over 18 years of age. If condition persists, consult your physician. No user-serviceable parts inside. Freshest if eaten before date on carton. Subject to change without notice. Times approximate. Simulated picture. No postage necessary if mailed in the United States. Please remain seated until the ride has come to a complete stop. Breaking seal constitutes acceptance of agreement. For off-road use only. As seen on TV. One size fits all. Many suitcases look alike. Contains a substantial amount of non-tobacco ingredients. Colors may, in time, fade. We have sent the forms which seem right for you. Slippery when wet. For office use only. Not affiliated with the American Red Cross. Drop in any mailbox. Edited for television. Keep cool; process promptly. Post office will not deliver without postage. List was current at time of printing. Return to sender, no forwarding order on file, unable to forward. Not responsible for direct, indirect, incidental or consequential damages resulting from any defect, error or failure to perform. At participating locations only. Not the Beatles. Penalty for private use. See label for sequence. Substantial penalty for early withdrawal. Do not write below this line. Falling rock. Lost ticket pays maximum rate. Nap was here. Your canceled check is your receipt. Add toner. Place stamp here. Avoid contact with skin. Sanitized for your protection. Be sure each item is properly endorsed. Sign here without admitting guilt. Slightly higher west of the Mississippi. Employees and their families are not eligible. Beware of dog. Contestants have been briefed on some questions before the show. Limited time offer, call now to ensure prompt delivery. You must be present to win. No passes accepted for this engagement. No purchase necessary. Processed at location stamped in code at top of carton. Shading within a garment may occur. Use only in a well-ventilated area. Keep away from fire or flames. Replace with same type. Approved for veterans. Booths for two or more. Check here if tax deductible. Some equipment shown is optional. Price does not include taxes. No Canadian coins. Not recommended for children. Prerecorded for this time zone. Reproduction strictly prohibited. No solicitors. No alcohol, dogs or horses. No anchovies unless otherwise specified. Restaurant package, not for resale. List at least two alternate dates. First pull up, then pull down. Call toll free number before digging. Driver does not carry cash. Some of the trademarks mentioned in this product appear for identification purposes only. Objects in mirror may be closer than they appear. Record additional transactions on back of previous stub. Unix is a registered trademark of AT&T. Do not fold, spindle or mutilate. No transfers issued until the bus comes to a complete stop. Package sold by weight, not volume. Your mileage may vary. If the flow controls supplied are not installed, this unit will not operate properly. Keep out of reach of children. When this set is used with other equipment, if the picture is not stable or the buzz sound is heard, try to change the mutual position of relevant equipment or take enough distance between them. This unit not labeled for retail sale. Phenylketonurics: contains phenylalanine. Close cover before striking. Mind the gap. No merchantability expressed or implied. Parental discretion is advised. Sold as a novelty item only. Although robust enough for general use, adventures into the esoteric periphery may reveal unexpected quirks. Not available in stores. May cause abdominal cramping and loose stools. Vitamins A, D, E, and K have been added. Not designed or intended for use in on-line control of aircraft, air traffic, aircraft navigation or aircraft communications; or in the design, construction, operation or maintenance of any nuclear facility. Container may explode if heated. May contain traces of various nuts and seeds.
This supersedes all previous notices.
KK4ELO
Smithville, Tennessee
Standard Disclaimer
WTF(udge)??? Lol I never thought about there being that many disclaimers out there till now
Sent from my LG-K330 using Tapatalk
jonwienke
VA
The proposed installation is kind of dumb. The speakers are firing into the seat and are going to be muffled. You'd be better off putting them on the dash or somewhere they can point in the general direction of your ears.
Delivers1234
Modesto, CA
Well. They sound good to me. I do t need them for the passenger. Maybe one day I will.
Thank you all for your input. When I finish I will put up pictures.
cmdrwill
So Cali
NOT dumb at all. Nice speaker installation, Sir.
Nice for those 'passengers' who do not like radios.
