Splitter for more than one scanner
bw415
Or for just a few dollars you can use a cable TV splitter. I have used them for over 25 years with multiple scanners and they work fine. Just make sure they cover the frequency range you need.
What cable should I use rg-58, rg-8, or rg-6
If it's the jumper from the splitter/amp, then just a short run of RG-58 is fine. For a short run of cable, the amount of loss is negligible. The amplifier gain will overcome that minimal amount of loss.
Plus, the more flexible cable will put less strain on the antenna jacks on the scanner.
4 feet of cable at 856MHz:
RG-8 - 0.164dB of loss (this is for the high grade 9913 type)
RG-6 - 0.362dB of loss
RG-58 - 0.594dB of loss
You probably would not notice 2dB of loss. No way you'll hear the difference in 0.4dB of loss between the RG-8/9913 and the RG-58.
You could absolutely do the RG-6, but again, you are looking at 0.2dB difference, and you'd need high grade test equipment to measure that.
The RG-58 is going to be a bit more flexible than RG-6, and way more flexible than RG-8, and it'll reduce the chances of damaging the connectors.
If you have the tools to make RG-6 jumpers and install the correct BNC connectors (no adapters), then that would be an option.
If you are buying jumpers, the RG-58 would be my choice.
Bonkk083
Union, SC
When using multicoupler will the signal be as good as before adding a multicoupler
