I think it depends on the exact scanner & f/w version
Negative. The channel reassignments only apply to 851-854MHz. You do not want the scanner mistaking anything after 854 as a reassigned channel.
This definitely an interesting issue as there are several aspects to it.
We're talking about this bandplan:
# BASE END OFFSET STEP
1 851.0250 859.0000 440 + 25 kHz
2 851.0125 868.9875 0 + 25 kHz
The scanner only receives a channel number (LCN) and does simple math to calculate the voice channel frequency. With one entry for LCN 0 and another for LCN 440 that should cover all rebanded 800 channels. No end channel or frequency is really needed; although some scanners want you to enter one. In this case, LCN 0 to 439 uses the first entry and LCN 440 and above uses the second entry. What should happen if the scanner receives an LCN of oh let's say 560?
Certainly LCN 560 takes you to an unused frequency in the rebanded 800 world, but that could be used during the rebanding process where both sets of channels are/were active.
In reality an LCN of 560 or more should never be received over a fully rebanded 800 system but how the scanner handles it varies. While 854.000 MHz is technically correct as the end frequency, it is my understanding that that does not work on some models. I don't personally have one of those models so I can't verify it.
For those that want to understand this issue more clearly or visually,
I posted this PDF file some time ago which illustrates the conversion from LCN to frequency for Standard (non-rebanded), Splinter and Rebanded systems.
