BSmithNC
Finally got enough parts in today to finish hooking up my CB radio in my 2016 Ram 3500.
I have a Uniden PC78LTX. 18’ cable with no coiled loops, that is attached to a Breedlove stake mount, with a firestik DM-4A dome mount, quick disconnect, and a 4’ firestik antenna.
I am using the built in SWR meter and seeing just under 3. Also, not sure if it’s normal but I don’t hear static or anything on any of the channels.
I have a ground strap on order that will go from the ground screw on the Breedlove mount to a spot on the frame of the truck. Also planning on bonding the doors, the hood, and the exhaust at some point.
Is the antenna actually grounded since I do not have a ground strap as of yet? Should I be hearing static or any noise at all?
Would like to make sure I am headed in the right direction.
