started my stream
rob8558
jerseycity, NJ
Re: Troop C
elias1988 said:
I'm buying my Pro-2096 tonight so i'm adding Troop C to my feed, it should be up and running in the next couple of days; it anyone would like to listen look in my signature for my feed info.
will be looking forward to that....unable to hear any Troop C, except for that of system wide broadcasts like marine stuff.
elias1988
West Creek,NJ
Re: Troop C
Joseph11 said:
Lucky you. You're not dedicating the PRO-2096 to your feed, are you?
Yes iam, a 500 channel scanner is alot better then a 30 channel scanner i use for my feed.
Joseph11
Re: Troop C
I'm sorry, but dedicating a $500 scanner for an Internet stream of the NJSP? That's a bad idea. If I had a PRO-2096, I'd use it for my own personal listening, and buy an older TrunkTracker (which is not the PRO-92) for the stream. The Central system is all analog, so why use a PRO-2096 for a feed like that?
elias1988
West Creek,NJ
Re: Troop C
Both Troop A & C are switching to digital soon, Troop B is already using it.
Joseph11
Re: Troop C
Troop B only has partial ability for P-25 CAI, not all sites are capable yet. I doubt Troop A & C will go digital any time soon.
dic
Weston, FL/Swampscott MA
Thanks Rob for the stream.
NJSP have been missing from online for too long.
A question for all of you NJ listeners:
There is an abundance of info online about the NJSP, but what I can't seem to locate very much about is how the actual patrol zones are organized on the Turnpike and I 80.
Does anyone have any info on the mile markers for those roads? And/or the other interstates?
Dic
RocketNJ
Pequannock, NJ
Actually Troop B & C are both fully capable of analog and digital communications at all sites now. Troop A may be coming online in October
RocketNJ
Pequannock, NJ
mattMrs31 said:
NOT UNTIL 2008! I AM WORKING ON THE SYTEM.
I guess you are not that invloved with the system then. B & C are already SmartZone Omnilink and are using a mixed mode setup which allows both analog and digital transmissions.
Some talkgroups are already using portables with digital (although very few). The majority of the units are still flashed and programmed for analog.
It will take a while for normal dispatch (2 comm, 3 comm, etc)to go over to digital, if they migrate at all.
HarleyDave
The stream is outstanding! I would have loved it if someone had this back when I didnt have a trunk capable scanner. I would like to do the same thing with the Morris County TRS eventualy, but I havent had much sucess setting up shoutcast. I was always looking for something plug and play like, but instead I find the uber difficult IT nerd special setups that make me remember what it was like taking the short bus.
Great stream, thank you for your contribution to the scanning community. *Present ARMS!* *ooooooooorder ARMS*
rob8558
jerseycity, NJ
not sure if anyone listens but if you do and you have any tweaking comments...please let me know. i am new to this stuff and just recently stopped paying for someone to host the stream and decided to do it myself, so there is a learning curve. i am intrested in knowing if anyone gets a rebuffering error from the stream..
thnx guys.
elias1988
West Creek,NJ
rob8558 said:
hey guys, i changed the address of my stream.....
mms://njsp.no-ip.org:8080/
Is there a problem with the address?when i try to open it with windows media player and real player it doesn't work.
rob8558
jerseycity, NJ
my apologies...yes the stream is down. i currently use my dsl to host the stream and use my cable connection for work. my dsl is down and i really dont want to move the stream to my cable because i use it for work. verizon is working on getting the dsl up...should be resolved by monday. i guess this is one of the drawbacks of hosting your own stream rather than pushing it to a server and having them host it.
i will post when back up.
rob8558
jerseycity, NJ
decided to move it over to my cable since it is the weekend. may have to take it down on sunday though....hopefully verizon can fix it on their end. so link is good!
