HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
While doing a quick scan of the airspace across PA at ADS-B Exchange, I noticed that there are two low level aircraft that keep appearing as TIS-B hits south of Pittsburgh. I guess I am still a bit fuzzy about TIS-B. Are these going to be military aircraft whenever you see these hits or would they also be federal or local law enforcement? Since the fed aircraft (DOJ, DHS, etc) can now turn off their ADS-B transponder when working surveillance, could it be them? The one I had highlighted when I took the screen grab certainly appears to be moving like a helo, tracking the river.
86381
Tech792
Central NJ
1320 local- DEVILs out in the warning area on 140.1
Also had HMX-1 in the area this morning and this afternoon on 143.825 FM. Probably practice runs for this weekends Bedminster potus stay.
freqhopping
The one at 1500 is probably a helicopter. Got to listen to ATC to figure it out.
The other with the overlapping icon is N293PC.
HM1529
I did tune in to ATC on liveatc.net to see if I could catch anything for the suspected helo heading along the river. No dice.
Of course, the next questions is, how did you arrive at N293PC from ~2B4469?
1545 local RCH 984 inbound McGuire C-17 #93-0601 for uploads 100k fuel,few pax
and a C-130 prop.
freqhopping
Because there aren't two aircraft occupying the same airspace.
This isn't an escort on top of AF1.
mdmonitor
0730- Couple of DE ANG C-130s Trek 01 (#96-1005) & Castle 50 (#84-0212) off Newcastle. Just heard them check in w/Potomac (12.65) for landing at Andrews. With Griffin CP (378.1) advising they will be ERO for onload. Griffin advises no ERO & they will have to shut down for onload.
BM82557
Berkeley Co WV
...check in w/Potomac (12.65) ?????
mdmonitor
Rgr on tape 0745 local had TREK 01 96-1005 and TREK 02 84-0212 calling Andrews CP for ERO onloads.
Like you said "Negative ERO so will shut down"
The Delaware guys don't get many Andrews upload work. Maybe more National Guard troops departing.
1030 local POLO 40 C-17 89-1191 also into Andrews will do ERO uploads.Maybe 10th Mountain Division guys from Fort Drum.
