freqhopping
This morning heard "Navy Tester Papa 74" calling McGuire CP..
Labeled as a Bell 407 type seems to have did round robin to from Pax as stopped McGuire for an hour or so.
TSTR74 Flight Tracking and History 28-Sep-2020 (KNHK-KWRI) - FlightAware
TESTER74 is still using the hex code for it's original registration N660AE which is now registered to a Bell 407.
ADS-B Exchange - tracking thousands of aircraft
Some of the test UH-72 are using their original hex codes.
168245 N566AE
168247 N573AE
Some for awhile were using a hex that was the same as their buno.
I think 168245 and 168249 have been the only ones to use their correct military hex code.
freqhopping
Hearing chatter on HMX-1 interflight 273.95 that sounds like it might actually be ANVIS22 08-0376.
freqhopping
HMX-1 interflight active with 51 and 53. I've believe it's a DRAGO flight preparing to overfly Arlington. Today is the ceremony for PFC Billy Johnson.
The Defense POW/MIA Accounting Agency (DPAA) announced that Marine Corps Pfc. Billy E. Johnson, 21, of White Oak, Texas, killed during the Korean War, was accounted for Aug. 7, 2019.
In late 1950, Johnson was a member of the 1st Marine Division, attached to the U.S. Army’s 1st Battalion, 32nd Infantry Regiment, 7th Infantry Division. He was reported missing in action on Nov. 30, 1950, after the enemy attacked his unit near the Chosin Reservoir, North Korea. Following the battle, his remains could not be recovered.
On July 27, 2018, following the summit between President Donald Trump and North Korean Supreme Leader Kim Jong-un in June 2018, North Korea turned over 55 boxes, purported to contain the remains of American service members killed during the Korean War. The remains arrived at Joint Base Pearl Harbor-Hickam, Hawaii on Aug. 1, 2018, and were subsequently accessioned into the DPAA laboratory for identification.
mdmonitor
1324- Couple of HMX-1 rotary wing acft (no calls noted) working on discrete (273.95)
Travis
OOPS didn't see your post before I sent mine.
1330- Acft I'm hearing using callsign 33 & 34 (one male. one female) chatting about shooting approaches at Solberg & Trenton. Acft 33 talks about using TACAN freq as Air to Air.
1335- Wild 1 flt (2 X F-16s 121st FS DC ANG) working ZDC Woodstown (363.0) check in at FL140 & cleared to FL210. Requests FL230 due to wx. Working discrete (238.175).
1339- Team 21 (KC-10 # 79-1949 AE01DE 305th AMW WRI) working ZDC Woodstown (125.45). Heading to WRI coming up from the south. Had been in AR211 in Missouri.
mdmonitor
1405- Team 22 (KC-10 # 79-1710 AE01DC 305th AMW WRI) working Brickyard CP (134.1) w/ inbound msg. Had been shooting approaches at Pittsburgh.
1427- Decoy 99 (C-17 # 00-0181 AE0817 167th AS WVA ANG Martinsburg WVA) working ZNY Harrisburg (133.475) working way back home from flt out to Nantucket area.
mdmonitor
1442- VC-25 # 92-9000 off ADW heading for Cleveland. AF1 working Potomac (125.525), ZDC Hagerstown (134.15) & ZOB Imperial (132.125) At 1450 AF1 reports visual on converging acft and reports no factor. At that time ADS-B showing Reach 100 at FL260 passing under AF1 at FL275.
1445- Reach 100 (C-130J # 14-5788 AE595C) working ZNY Harrisburg (133.475) & ZDC Hagerstown (134.15). Departed from Bangor ME and is heading southwest.
1450- C-32 # 09-0015 AE4AE6 off ADW. AF1 back-up? SAM45 working ZDC Hagerstown (134.15) & ZOB Imperial (132.125).
mdmonitor
1540- Toxic 62 (C-12 # 96-00122 Army Chemical/Biological Command Aberdeen Proving Grounds) working Phillips AAF (126.15) for landing. Had departed from Columbus OH. The Batelles Corp Chemical Biological Radiological Nuclear and Explosive (CBRNE) Defense Group located in Columbus OH.
1553- Acft Brave 1 working on ArNG discrete (150.55). ADS-B showing both UH-72 # 13-72275 & UH-72 # 11-72210 active in the Weide area.
1350- SAM 740 (C-37 # 18-1947 AE6962 89th AS) off ADW heading west.
mdmonitor
1612- Navy Tango Papa 18 (T-38C # 638185 AE1397 NTPS PAX) shooting multiple approaches at DOV (132.425).
1615- Tester 17 (T-38C # 701579 AE1396 NTPS PAX) returning to PAX for approaches (250.3) after multiple approaches at DOV.
1618- Air Force 2 (C-32 # 98-0001 ADFEB7 1st AS) off ADW heading northeast.
1627- Bass 70 (E-6B # 163920 AE0412 VQ-4 Det) approaching PAX. Had departed PAX earlier and worked in the warning areas off the GA/FL coast.
MtnBiker2005
San Diego County, California
MtnBiker2005
WWI111 = N451KR
WWI111 = Mode-S: A576C4
A Gulfstream G-IV, making first appearance in our data, flew ILG-BKL, operated by Worldwide Jet.
https://globe.adsbexchange.com/?icao=a576c4
https://jettip.net/blog/tracking-the-2020-us-presidential-campaign-aircraft
https://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=N451KR
KBKL - Burke Lakefront Airport
