mdmonitor
0922- Flt of DC ANG F-16s (call missed) check in w/ZDC Linden (322.55) requesting direct to Evers MOA. also on discretes (238.175 & 319.175).
0935- SAM 265 (C-37 # 09-0525 AE4A81) off ADW heading northeast. Working ZDC Woodstown (125.45).
0944- Axeman flt (4 X A-10Cs 104th FS MD ANG) off Martin State. Probably heading for Kiowa MOA. Working ZNY Harrisburg (270.3).
0950- Couple of NJ ANG F-16s (no call noted) working on discrete (298.6).
mdmonitor
0955- Mig flt (2 X T-38s 71st FS Langley) working in W386 (350.05).
0958- DeeCee 31 (KC-135R # 61-0307 AE049A 756th ARS) off ADW heading south working ZDC Patuxent (133.9). Working Liberator Ops (351.2) w/departure msg.
1000- Tester 10 (T-38C # 158198 AE1392 NTPS) on NTPS Ops (123.2) w/area PIREP.
1008- Bully flt (F-16s DC ANG) off ADW (257.2) heading for Evers MOA & working ZDC Linden (322.55).
screenersam
I hate motrbro
Somerset County, MD
news article; railgun ops (maybe) down Virginia
***The advisory, published by Naval Surface Warfare Center, Dahlgren Division and republished by Maryland’s The Bay, states, “NSWCDD plans to conduct range testing, Tues. - Fri., Dec. 1-4 from 8 a.m. to 5 p.m. that may produce very loud noise in communities surrounding Naval Support Facility Dahlgren.”***
I'm guessing there will be airspace issues down there next few days
dparana
Those Four A-10s are are up here in the DUKE MOA. Working 266.60 A2A and 301.60 as well. Sounds like they are doing simulated ACM with each other. On a conference call, hard to keep track for play by play.
rjsincs
Looks like Duke Moa may be active today and tomorrow. We will see if the weather factors in.
dparana
Dave,
Thanks for update. I lost them after Harrisburg.
This is an AXEMAN Flight and just contacted Cleveland Ctr on 353.85 and will be RTB in about 5 Minutes.
By the sounds of it, they are really yanking and banking this last engagement...FOX 2 Away!
OK, they are headed your way mdmonitor
mdmonitor
Dave
Thanks for heads up.
If they follow normal procedures you should see more of them during the day.
mdmonitor
1148- Nighthawk 11 (HMX-1 MCAF Quantico) working Potomac (125.65) for approaches at ADW. Had AE0874 (in database as poss H-3) working approaches at ADW at same time.
1205- Army 557 (Dash-8C # 15-00557 Manassas) operating over MD Eastern shore. Working orbits at FL135 between Ocean City MD & southern DE.
1210- Tester 12 (T-38C # 158200 AE138D NTPS) working Bay Watch (354.8) reporting speed run at Mach 1.1 at FL350.
1220- Unid acft (no call noted) working on PAX test discrete (267.0).
Do we have VIP travel again finally? TFR for tomorrow (VP or President Elect?) in MEMPHIS, Tennessee. FAA Notices (not TFR yet) for December 04, 2020 in the vicinity of Atlanta, Georgia and Savannah, GA at 2999 ft, and for AF1 on December 05, 2020 in Valdosta, GA at 17,999 FT MSL
TFRs issued (Memphis tomorrow). Wondering if the 2999 ft msl is for Pence or possibly Biden. Be interested to watch that, I'll be at work so hope you all will keep us updated here.
Couple SPUR tankers eastbound to New England area..
SPUR 59 60-0346 Mi ANG
SPUR 82 59-1506 Iowa ANG
Checking adsb-x sure is busy day all across the country for Mil aircraft..
Guess all back in action after long T-Day Holiday.
freqhopping
TROY4 helo with DCA tower 134.35, eastbound from Wolf Trap. Maybe one of those SD ArNG H-60s?
