Sticky Thread For Mid-Atlantic MilAir 2021
vgames15
Elsmere, Delaware
1000- lots of talking on 143.825 (HMX). Will miss hearing someone on the radio, a flyover and trying a new route through the bravo on the way home. All one sided.
1009- DRAKRO21? says to ILG ground are now nighthawk 21 flight departing VFR to the south
The pair just overflew me back Westbound may take shortcut over APG area. Clear day and purty green paint :)
BM82557
Berkeley Co WV
Unid with bad code of 424BA0 as BOE005 showed up on my local ADSB setup while I was out, ADSBExchange shows it originated at Georgetown DE and currently over South Dakota heading NW towards Seattle
wv2vvl
Bucks County, PA
1722Z 237.15 REACH 591 working BRICKYARD CP (AMC McGuire) ref fuel & lav services
288.0AM Constant high-pitched tone. Does not sound like a pure tone. Data? The source is 50-100 miles away as it does fade out with atmospheric condx. Could be McGuire.
1740Z 251.2AM - UnIDed aircraft working CP
134.1AM UnIDed aircraft calling Dover CP
Receiver: ICOM IC-R8600 Hybrid SDR
Antenna: Diamond 3000 Superdiscone @ 480' AMSL
So far I've programmed in all the 25 kHz military FM channels from 30.000 to 60.000 with CTCSS decode of 151.4 Hz + most of the listed VHF & UHF military channels for the metro NYC-Phila area. So far 860 channels which take 8 sec to scan.
While most mil activity in the FM band seems to be concentrated below 50 MHz, I have heard the NJNG using channels around 57 MHz when they were on flood control security duty in Bound Brook, NJ. I also found a note on 65.000 in an old log book. So I plan to add the remaining channels between 60.025-87.975.
It was not surprising when I had a 6M repeater on 53.25 without CTCSS to have military comms on 52.250 key it up. Most folks don't realize that the military is the primary user of the spectrum & everyone else, amateurs included, are secondary users. An example was the ban on amateur operations during WW2.
There have been a number of openings on 50 MHz over the past few months but no military skip yet. I also monitor 30.000 without CTCSS as this channel gets active when the band opens.
I also plan to add the bc station harmonics that I have copied in the past (AM mode).
Jack
Bucks County, PA
Checking morning tape 0900 local had Salty Dog-11 flight of two at FL230 with ZDC UHF says will be making a Hudson river Run.
"We will be about at 2,500 feet when entering the Mouth of the Hudson river"
The Navy sure likes doing that morning Hudson River run in their F/18's ..Once a Month at least it seems :)
Caught them on return trip 1000 am local says will work R-4006 (Ches Bay) before RTB.
Here they were back in end of June this year.. Two F/A-18 jets fly over Hudson River and Jersey City - YouTube
TerryPavlick
Wallingford PA Villas NJ
Jack
Bucks County, PA
Jack
Look for local in-house interference or intermod for the tone on 288.00 I get it here as well on some of my radios.
Terry
