Sticky Thread For Mid-Atlantic MilAir 2021
Reconrider
Inside the Galaxy
Radio Galaxy
Any body willing to share some CT frequencies? I'm new and just got my DPD mil air antenna last week. Beed using search but would rather have an actual list with known hits.
If you read through this thread and last years thread of the same name you will find many freqs, also check the RR database they are added in there when confirmed.
Tech792
Central NJ
Not sure if the Lakehurst NAS traffic on 230.875 is related to the CAP?
139.875 Tanker Interplane
268.025 Tanker Interplane
315.9 A/R PRIMARY
228.0 SWITCHED TO THIS FOR A/R
The 230.875 is not related to the CAP. This is ongoing airborne reconnaissance testing with the DH8C aircraft that is currently flying patterns around Lakehurst.
mdmonitor
Attached is a list of the Milairs freqs heard in the Mid Atlantic area which I put out every 3 months. You should be able to hear alot of these with your new antenna/
  • Mid-Atlantic Milair freqs-Mar 2021txt.txt
pro106import
Milford, Ct. perched high above Long Island Sound
I attached my list.
Enjoy, Bob
PS.. if you are on Facebook, some of the Northeast milair hobbyists are also up on Facebook Groups
  • MILAIR 2-6-21.zip
Not seeing ADVICE-61 on mode s but still hear on radio.
"The New Air Force One: Flying Fortress" will premiere on Feb. 15 at 10 p.m. on National Geographic.
Reconrider
Inside the Galaxy
Radio Galaxy
I attached my list.
Enjoy, Bob
You guys are awesome. Thanks so much
I'm on facebook but I don't use it a lot, I'll try to find the group and join it though. I'm not close to your area pro106, but I should be able to get stuff from westover air force base when I figure out how to get my antenna outside.
Edit: what scanners are you gents using?
I just purchases an icom r30 and will be here next week. Currently I'm using my sds100 which hasn't gotten much, but I think it's more likely that my antenna is inside my brick house lol
mdmonitor
1325- Decoy 01 (C-17 # 00-0182 AE0818 167th AS WVA ANG) doing some local flying & pattern work at Martinsburg. Probably the Sqdn Cmdr getting his flying time.
1332- Unid acft checking w/ZDC Brooke (285.45). Sound like ftrs so maybe CAP related.
mdmonitor
1402- Nobles no working on 363.9. I have that as a W386 common. Chatting about wx down near Savannah. They not liking the forecast and should be tough landings for night CAP ftrs if forecast holds true. They mention forecast wx up here tomorrow and aren't looking forward to that either.
1405- ADS-B showing Ramsy 77 (C-32 # 02-4452 AE0449 105th SOS NJ ANG) working his way home. Departed from San Juan PR. Heard end of a xmission on 251.2 (Torch CP) so that may have been him.
1417- Score 79 working Bay Watch (354.8) off of the Test Track & on approach to PAX.
1420- Noble 21 flt working ZDC Franklin (235.625) cleared direct to Savannah.
1421- ADS-B showing KC-135R # 58-0009 AE058C IL ANG Milwawkee) heading towards our are, over northern PA now. Might be next CAP tanker.
58-0009 is ADVICE-62 128ARW Wi ANG. NOBLE 21,22 in the CAP
Notice that SPUR 92 has setup racetrack North of Knoxville Tn.
mdmonitor
Duh--another geographic blunder :cautious: 1421- ADS-B showing KC-135R # 58-0009 AE058C IL ANG Milwawkee) heading towards our are, over northern PA now. Might be next CAP tanker. Every knows Milwawkee is in Wisconsin
1447- Devil 91 flt ( 4 X F-16s 119th FS NJ ANG) working ZOB Indian Head (327.1) Wants to split flight--Devil 93 & 94 will go to McGuire and Devil 91 & 92 will head for Atlantic City. Devil 93 & 94 cleared direct to McGuire via Harrisburg. Devil 93 working ZNY Harrisburg (133.475).
1450- Two NJ ANG F-16s (no call noted) working Giantkiller (296.9) then on discrete (298.6)
1454- Advice 61 working ZDC Dupont (307.25) requesting clearance back to Selfridge ANGB Michigan.
1455- Unid acft (missed call) working Devil Ops (261.) advising that Devil 91 & 92 are headed to ACY and that the unid acft has 35 pax they will unload then head back to McGuire.
1505- Devil 95 working ZDC Kenton (354.15) then working DOV approach (257.875) for a couple patterns.
AirScan
AR with PEACH 01, B703, 97-0200. Seems odd using a SPUR callsign to AR a PEACH, common to see them use standard unit callsigns for that ?
update - I see now SPUR 92s destination is MacDill so I guess the PEACH was just a pitstop on the way to the Super Bowl ?
ZNY3347
Harrisburg, PA
Four F-16's flew over my house (Lancaster, PA) around 1500 at maybe 10000ft? Heading direct towards McGuire.
B1-B Rehersal
