Sticky Thread For Mid-Atlantic MilAir 2022
1515 local See on ADSB a TORCH-34 Buff FL250 coming East thru Indiana just Northwest of Louisville and came out of Edwards California.
Likely two of them? They like going in pairs. Maybe they will buzz the Naval Acadamy or Niagara Falls :)
Looks like TORCH-34 hit bombing range or did odd low level circles in Ohio West of Columbus and headed back West via same course.
BTW that tail TORCH-34 showed as #60-0036 (AE56EA) which belongs to the 412th TW at Edwards AFB.
Very rare out East here so who knows why it had to cross 3/4 of the US to do whatever.. Maybe Edwards will release news about it someday.
Vid of this same tail testing a couple years ago at Edwards.Clean looking machine!
B52 ARRW Hypersonic evaluation test at Edwards Air Force Base 12 JUN 2019 - YouTube
Minot B-52 #60-0023 was busy just across border in Manitoba Canada today just West of Winnipeg on the racetrack.
wbagley
Near Louisville, Kentucky
For those of us who feed ADS-B data to FlightRadar24 and other tracking networks with homemade receivers, FR24 wants us to turn off MLAT:
Disable MLAT if sharing with other networks
Today, 12:52
This only relates to volunteer receivers and NOT Flightradar24 equipment.
No action needed if you have receiver provided by Flightradar24.
Hi guys,
As a lot of you have seen, we sent out an email requesting that MLAT be disabled if sharing with other networks.
There is a lot of confusion revolving around this so this post is to add a little clarity.
If you are sharing with other networks ie. FlightAware, Radarbox, ADS-B Exchange etc please follow the below guide:
Please disable MLAT on either your fr24feed.ini configuration file.
Open Command Prompt (windows) or Terminal (MacOS/Linux) and enter the following.
ssh receiver@ipaddress
Once you are at the command line,
sudo nano /etc/fr24feed.ini
receiver="avr-tcp"
fr24key=" "
host="127.0.0.1:30002"
bs="no"
raw="no"
logmode="1"
logpath="/var/log/fr24feed"
mlat="no"
mlat-without-gps="no"
Or on the Web UI
http:// your receivers IP address:8754
ie. 192.168.123.456:8754
As per the initial email,
We write to you with important information concerning the set-up of your receiver.
Firstly, we would like to thank you for your continued support as a volunteer feeder. We depend on volunteers such as yourself for ADS-B data from around the world and your data feed is much appreciated by the Flightradar24 community.
Important information
If you intend to share data to networks alongside Flightradar24, in your Flightradar24 receiver please disable MLAT to the following settings: MLAT=“no”and MLAT-without-gps=“no”. This is to ensure the quality of the data we receive and use and to reduce incompatibility with other services.
Thanks,
Flightradar24 Team
Disable MLAT if sharing with other networks - Flightradar24 Forum
wbagley
Yes that email went out to all FR24 feeders.
As they clarified, only folks with non-FR24 receivers need to turn off MLAT.
Today, 12:52
Hi guys,
JetWash
Fairfax, VA
ADSB-X Showing VMBA10 FAT ALBERT doing repeated runs at Annapolis...some as low as 300 feet AGL. At one point above the intersection of Ritchie highway and route 450 the track shows they were at 175 feet. If you didn't know better, you'd think they were on strafing runs!
freqhopping
Add about 300ft to that and you'll have the true altitude.
