Sticky Thread For Mid-Atlantic MilAir 2022
pro106import
Milford, Ct. perched high above Long Island Sound
Pro
Goody are T-38s from 71st FS at Langley. 233.525 is one of their discrete freqs & 350.05 is one of the W386 common freqs. Darkstar is usually a notional (simulated) AWACS station.
Thank You Glen! Yes I looked up Goody on your callsign list and didn't see it. Only shows Luke AFB.
I wonder if those T-38's are using hifgher power than the normal 10 watts. They seem to make it up my way well even when off Va. Beach.
I used to hear Darkstar up here all the time back when Otis was open working with them in W-105. Seems like they moved down to 107 / 386 areas for a while now. I always assumed it was an actual AWACS aircraft.
350.05 is also used by Barnes with GK at times up in W-105
mdmonitor
Pro
In my experience one of the ftrs usually takes on the role of Darkstar for more realistic ACM training.
Goody isn't on the list (yet) but based on your monitoring and the use of the freqs, I'll add it in.
Ron
0530 local NOBLE flight MA ANG coming South with Huntress 260.900 says without the tanker NATION-21 will
only have 30 minutes of fuel to play with and will have to divert to Shaw AFB. A/A 259.900
0536 Talking with Huntress about working a Hot Pit when down there to get back up into the CAP.
