Sticky Thread For Mid-Atlantic MilAir 2022
Hbright
P6 report says Zelensky will stay in US for another day with meeting at the Pentagon.
Just talked to Penguin Six and his crew. Zelensky departed via ADW just after the speech. People at ADW saw two aircraft depart, neither on transponder, just after 2100E. One appears to be a C-40 (I think 02-0042) and the other was "smaller." I will check 125.65 archives to see what I hear, but did anyone hear anything on 118.4? He's definitely on one of the aircraft that took off.
Update. SAM910 departed at 2104, which matches up with when local PD said he was wheels up. SAM910 was direct PALEO and then switched to Potomac 124.55 and soon thereafter to Wash Ctr 125.45.
listen13579
Alexandria, VA
Reach 840 did a u-turn off the coast of Nova Scotia. Forgot something back at Andrews?
Update at 2227: Boston Center gave them a new routing back to DOV. Maybe they were accompanying the SAM flight part of the way?
Hbright
He's posting up at Blair House - or that was the initial plan.
The plan was always to leave tonight. not sure where the rumor started that he was staying the night. From WH press briefing at 1830E last night:
"[T]here will be an address by President Zelenskyy to a joint session of Congress demonstrating the strong bipartisan support for Ukraine. And then President Zelenskyy will return, after just a few short hours on the ground, to his people in Ukraine."
He did use Blair House between when he arrived at ADW, and his meeting w/ POTUS at the White House, no more than 2 hours. He may have gone back there after his White House engagement and before his Capitol visit, but that would've been brief if so.
maus92
The OP
Perhaps some disinformation then, to add ambiguity about his actual departure time. I can see why he doesn't want to be out-of-country for too long, especially around Christmas, and why he doesn't want his return to be tracked by commercial sources. But I can also see why he might have reason to stay another 18 hours.
listen13579
Alexandria, VA
Reach 840 has a pressurization issue returning to DOV. They let center know to coordinate slower descents from FL180
paradiver
Middle River, MD
By the ACARS messages looks like there was some IFE
ACARS message:
AES:AE08E3 GES:02 2 .00183A - #MDFTX/ID00183A,RCH840,JJWGC190E355/MR1,/FXC2 WISHES TO KNOW IF YOU ARE DIVERTING BACK TO AMERICA. FM JEFF3235
AES:AE08E3 GES:02 2 .00183A - #MDFTX/ID00183A,RCH840,JJWGC190E355/MR3,/FXOK UNDERSTAND. PLS TELL ME WHERE YOU ARE GOING AND ETA. FM JEFFAD6C
AES:AE08E3 GES:02 2 .00183A - #MDFTX/ID00183A,RCH840,JJWGC190E355/MR4,/FXTHANK YOU I WILL PASS IT ALONG. JEFFA4CE
AES:AE08E3 GES:02 2 .00183A - #MDWXR/ID00183A,RCH840,JJWGC190E355/MR5,43/MTKDOV,0409,TAF KDOV 220409Z 07006KT 9999 (7SM) FEW080 T02C A3030DAA1
AES:AE08E3 GES:02 2 .00183A - #MDFTX/ID00183A,RCH840,JJWGC190E355/MR6,/FXNO SHOW STOPPERS AT KDOV. FM JEFF1693
Makes sense press problems as RCH-840 flying low rtb Dover at FL 18k.. Sure sign of pressurization problems 145AW NC ANG tail.
This tail departed Andrews.
2322 local RCH-840 with Dover apch 132.425 says no emergency and we have already communicated to folks on ground
our problem.
PenguinSix
He went straight from the press conference to the Capitol. We were trying to get there before him from the WH after the press conference but failed.
