2330 utc: 5696.0 USB Camslant calling C/G 2128.
2358 utc: 5696.0 USB Camslant calling Sword Fish 28 and asked for flt ops and position.
166374 USMC374 12:42:17.973 UC-35D MAW-4
06-6165 ROYAL50 19:03:18.219 C-17A 436thAW
86-0201 GONAVY 14:21:04.453 C-20B 89thAW/99thAS
[/SIZE][/FONT]
0955 CG 6507 HH-65C to CG 6530 HH-65C A/A 345.000 reports in vicinity of Havre De Grace bridge.
Mention of a jumper.Both seemed to be bugging out with report of boat picked someone up.
CG 6507 says will pick up I-95 westbound to aircraft barn.CG 6530 says going to NCI deployment
sounded like.
1025 RESCUE 30 with Phillips AAF 126.150 moving South from Havre De Grace.
Also showing a Sikorsky S76C on RB for last 20 minutes N2577H (A274D4).Could be him.
1042 That Sikorsky still hanging around at 2950 feet.
Tin,
Some USAF guy with a sense of humor ???
JohnFB said:Ref 166374:
Passed thru NE @ 1455Z as MARINE 374 heading northeast thru Augusta sector. Maybe he went to Bangor or Brunswick and then back down your way.
Ref 06-6165:
Working in AR212 with TEAM 16 0025Z [Tue] on 238.900
Or they had to use a Navy avionics crew during the holiday period who snuck one in.
A Charleston C-17A, 98-1191, has run off the runway at Kandahar, Afghanistan and suffered significant damage. It was being flown by a reserve crew from the 315th AW at Chareleston. That's the fourth C-17 mishap in Afghanistan in the past six years. The three others were:
(1) In August 2005 at Bagram Airfield, a pilot mistakenly thought the runway
lights were 180 feet apart. In fact, the lights were 100 feet apart. When
the jet came down, the right main landing gear was 10 feet off the runway,
causing the plane to roll off the right side of the runway.
(2) In April 2003 at an undisclosed airfield in Afghanistan, pilots landing a
C-17 did not realize the left half of the 180-foot-wide runway was under
construction. The plane’s left landing gear rolled through the construction
site before the jet came to a stop.
(3) And in January 2002, a C-17 attempting to land at Kandahar came down in a
minefield 2,000 feet shy of the runway. The pilot was able to get the plane
airborne and safely land at Incirlik Air Base, Turkey.
That last one would leave you shaking for a bit after leaving the cockpit.
Or they had to use a Navy avionics crew during the holiday period who snuck one in..
airborne and safely land at Incirlik Air Base, Turkey.[/I]
Guys,
1022- Just had 2 F-16s--- callsign sounds like Rizo 21 id self as NJ ANG from Atlantic Cityw/Bay Watcvh (305.2 & 270.8). Anyone else hear them to confirm callsign? It's a new one (for me at least) for the ACY ANG guys.
Guys,
Yeah Ron, I can confirm that callsign is WEASEL. It's an old one for the New Jersey guys. They also used it last week. Now they just need to pull TATER out of the closet too.
Heard them on 270.8 and their interflight freq 138.875.
WEASEL 21 pronounces it kind of funny...22 says it clearly.
They depart Patuxent R-4006 (305.2) and get handed to ZDC-Cape Charles on 256.8 as they head for home....then to ("Push 7") ZDC-Casino 285.4 at 1121....and at 1122 to DEVIL Ops 261.0 where they check in as a flight of two, both in Code 1 status. At 1123, it's ("Push 6") and they check in with ACY Approach 327.125 for approach to the home runway 31.
1126: DEVIL 3 (13) checks in with DEVIL OPS to report 10 minutes out and gives status of each of the three aircraft in the flight...261.0 (Interflight on 138.425)
1127: DEVIL 11 flight with ZDC-Casino checks in at 8,000 feet requesting direct Atlantic City...285.4
Wasn't able to hear either the WEASEL or DEVIL flights on Tower freq 239.0
Mark/Travis/Dave: If you logged C-FEMT (hex C00BDC), it's an LJ-36 air ambo (at least sometimes). I have a logo I made for it: (85x20)
SCORE 04 was doing touch and go's at Dover UHF,did rtb South towards Norfolk or Pax.
We have a unit for that callsign? I forget.
Paul said:Just a few from Scott AFB (BLV) today…
0918L 125.200 SL A/D – AVALON 73 (C-9A 375AW Scott AFB) depart BLV 1700’-3000’. Cleared to 6000’ direct Centralia (ENL) VOR. Going out ENL-BIB-TTH-BLV local trng mission. QSY ZKC-ENL-L 127.700.
0921L 127.700 ZKC ENL-L – AVALON 73 cleared FL230.
0922L 383.200 Scott CP – AVALON 73 departed at 1517Z.
0923L 125.200 SL A/D – SWIFT 32 (C-21A 375AW Scott AFB) departed BLV 2000’ – 3000’ for local training msn. Request conducting hold at DUTMY then multiple GPS Rwy 32L approach circle 14R.
0928L 125.200 SL A/D – AVALON 75 (C-9A 375AW Scott AFB) departed BLV 2000’-3000’ for local training mission. 1st approach request - ILS 14R approach.
1002L 128.250 BLV TWR – AVALON 75, SWIFT 32, TWR, and SL APP reporting unknown VHF ELT.
1031L 125.200 SL A/D – SWIFT 32 terminating with radar, will stay in the local pattern with TWR after approach.
1033L 128.250 BLV TWR – SWIFT 32 on final rwy 14R will stay with TWR requests the option.
1104L 383.200 Scott CP – PACER 45 asking Scott CP to relay their 1429Z arrival and 1653Z departure from Perryville, MO airport (K02) to ADW, and that they will arrive ADW in about 1.5 hours. Also mentioned a PACER 99 making the same route, and asked if they contacted Scott CP.
Mark, I had a SCORE 08 callsign tied up with hex AE03B1 a few days ago - displayed in Mode-S. That's tentatively identified as a KC-130F from VX-20 at Pax.
Way to go Paul! Good to see a log from you. As we've discussed, there's a lot of interaction between Scott and Andrews so we see a lot of the same aircraft. Thanks.
PACER 45 = C-21A, 84-0095, 457th AS Andrews
PACER 99 = C-21A, 84-0094, 457th AS Andrews
