Strange RF issues
KD8TZC
Cleveland, Ohio
I have recently installed a G5RV Jr antenna in the attic so I can work CW on the 40 and 15 meter bands. Previously, I had just used a 10m dipole with a balun.
The coax line running from the basement into the attic co-habitates with the satellite TV line going to the master bedroom. In the master bedroom my wife informs me that when I am on the radio and she is watching tv in our room, it will do all kinds of strange things (change input sources on the TV, and other things). I don't know if the radio is causing the TV to come on or not. The attic where the antenna is, is right above our master suite.
Any ideas what I can do to eliminate this issue? The G5RV was used in hopes that it would give me the bands that I can use, but I don't recall having this issue with the 10m dipole (which was resonant right around 28.4MHz). The G5RV has to use a tuner to get it into an acceptable SWR, so I'm sure it is radiating garbage off the feed line.
Would a ferrite choke or toroids on the TV help, and if so, where would I put it (on the coax for the TV, power cord, etc)? I don't seem to be having any issues with the Satellite box acting strange, just the TV. Would a balun at the point of the coax and the ladder line for the G5RV help?
John
